can i plug these?
Old Jan 26, 2012 | 12:29 PM
christmastree's Avatar
Default can i plug these?
can i plug these these holes and be ok? if i am not mistaken the one on the left is oil temperature and it is optional. And the two on the right are are for the pcv (which i am wanting to get rid of). please correct me if i am wrong. As far as relieving the pressure from the case i will put a breather filter on the valve cover. so here are my questions...
1) can i plug those without any repercussions?
2) will a mini filter on my valve cover be enough to vent out the gasses?
3) would i be better running a catch can? (in which case i was thinking i could run a hose from my valve cover to a catch can and then from the catch can to the hole i would be plugging on the left)
my set up is an itb lsvtec
here is my set up if you want the details: https://honda-tech.com/forums/all-motor-naturally-aspirated-44/obx-itb-lsvtec-build-thread-3020701/
Old Jan 26, 2012 | 12:37 PM
4cylfiend's Avatar
Default Re: can i plug these?
-The ones circled in GREEN will get vented into a catch can
-The ones circled in BLUE can be blocked off.
Go-Autoworks.com the plugs and direct screw in -10 fittings for the block.
Old Jan 26, 2012 | 12:40 PM
4cylfiend's Avatar
You can also get a -10 bung to weld up to your valve cover and that line can also be ran to the catch can. They also offer catch can kits with all the fittings, lines, and hardware to install the catch can.
Old Jan 26, 2012 | 12:48 PM
to be honest i would prefer to block them all off and run a mini filter on my valve cover. way more of a simple set up. HOWEVER, if that wouldnt vent enough or will cause me to sprsy oil through the mini filter i will go the catch can route. In which case i was thinking i could run it how i was saying. I have seen it ran the ways that you guys have said BUT i dont see why running one line from the valve cover to a catch can and draining it back down through the oil temp sensor hole (the hole that is already tapped) wouldnt work
Old Jan 26, 2012 | 01:40 PM
95skunkedgsr's Avatar
your going to need a catch can the mini filter aint gonna be good enought to vent it
Old Jan 26, 2012 | 02:11 PM
thank you sir. if anybody disagrees with this speak up. if not i will be making a catch can set up
Old Jan 27, 2012 | 06:07 AM
90efhatch's Avatar
Agreed.
miahjera04
Nov 22, 2018 10:06 AM
Nisif
46
Apr 18, 2008 03:49 AM
mahatma
Jul 19, 2007 01:40 PM
ToeJam
Feb 17, 2007 05:44 AM
frozenb
Mar 31, 2005 09:12 PM
