space-age strut bar material
I wanted to experiment with a cheap alternative to aluminum or steel strut bars. I want to see if I can make a functioning strut bar out of wood compare to my current one and no bar as a control. what do you think?
Oh and If I make it out of bamboo and it works can we say its JDM?
Try red oak. Very rigid, and gives a neat rustic look when stained.
x2 Although a bit expensive and can be tough to find locally.
How is wood space aged? haha just kidding, but on a serious not i think the fact that wood is not as rigid as metal would be your down fall. Think about it the tensil strength of wood is far less then any sort of metal hands down. Any wood will flex under pressure, the beautiful thing about aluminium is that is flexs far less and is a light alternitive to steel. A strut bar that flex's too much is useless, and i would even consider red oak to be too weak to solidly hold the struts together. That is just my 2 cents.
Yeah, wood is actually a space-age material in terms off specific stiffness.
Tensile strength is quite different from stiffness.
Stiffness is tied into density, so there isn't any free lunch really. Also, the larger the diameter, the stiffer it will be. That is why, when approached for a strut bar with creative license, I made this...
Please disregard the owner's pink molested intake...
That is 2.5" OD .063 aluminum with solid hats. Compare that to a 1" bar, or the goofy, space-limited oval designs.
The bars with bolts and pivots are a joke.
haha im just trying to have fun. lets say daily driver. what other info do we need... its a green civic. if this takes off ill send everyone who helped a free one.
You guys better hope this isn't another Joe Harmon. A wooden strut bar could be very functional if done properly.
http://www.google.com/m/url?ei=7SwiT...Wj1sK_xRdtorig
The problem with wood is it is only strong in compression. It also will expand and contract as moisture content and temperatures change, which happenes alot in an engine bay.
http://www.bikebamboo.com/
Here is another pro wood site, I guess people are making other versions of these in China to reduce carbon foot print on a large scale too. That bike in the link has a 4 lbs frame, and is referred to as a natural composite. Just a thought
spaceman00
Apr 21, 2007 11:09 PM
dohcdelsol
Jun 1, 2004 06:06 PM
BADGUYNY
Dec 15, 2003 03:32 PM
