Need Help With Replacing Clutch
Old Jan 25, 2012 | 11:43 AM
Chobits16's Avatar
Default Need Help With Replacing Clutch
So i got my new clutch all bolted on and i am bolting on my transmission now and i cant seem to get the half shaft to pop in i can get everything else flush besides the back side where the half shaft it, It is all still in the car so if anyone had any suggestions please let me know would be greatly appreciated.
Old Jan 25, 2012 | 01:23 PM
JOE_DC4ever's Avatar
Default Re: Need Help With Replacing Clutch
What do you mean that you can everything else flush besides where the half shaft is?
Old Jan 25, 2012 | 02:35 PM
Chobits16's Avatar
i mean that i can get just about every bolt all the way tight besides the one going into the half shaft.
Old Jan 25, 2012 | 04:27 PM
So you have everything bolted up fine but the three 14mm bolts that hold the half shaft in place to the block are not lined up? I would try 1) make sure your half shaft is fully seated in the transmission 2) loosen all three 14mm bolts and thread each by hand before tightening any of them 3) If this is not possible then the transmission may be ajar with the block, make sure that the transmission is sitting flush with the engine block all the way around (sometimes those little keys/pins that align the transmission to the block can pose problems like this)
Old Jan 25, 2012 | 04:31 PM
Dc4LsTeG's Avatar
EK9
Is your tranny bolted up all the way to the motor?
Old Jan 25, 2012 | 07:31 PM
standy xsi's Avatar
Where did you get the intermediate shaft from?
are you SURE you didnt bend it takeing it off?
Old Jan 25, 2012 | 07:59 PM
sirtef9's Avatar
That thing would never bend lol. you need to slip the half shaft in before it gets bolted down..
Old Jan 25, 2012 | 08:38 PM
standy xsi's Avatar
ive bent one trying to get the end ov a c.v joint out.... that was with excessive fource thoe lol
yeah man slide it in first! then you can flip the bracket up and align it
then put your bolt's in
9/10 time's i have to slide myn back a inch or so
Old Feb 1, 2012 | 03:09 PM
Chobits16's Avatar
thanks for all the suggestions i will try them or if anyone in washington (tacoma area) wanted to come help me i can throw some cash there way
Happy Gilmore
Dec 2, 2008 01:55 PM
LSEGHATCH
Jun 28, 2006 12:21 PM
adictionbass
Jan 29, 2005 05:50 PM
