Transmission help
So i have a b18a1 in my crx and i recently swapped transmission because my old one was going out. This new one felt great, until i got to 5th. i'm not sure if i have a 4spd trans or 5th gear is just gone?
I can feel it go in to 5th but it just feels like its in neutral. i stopped my car, didn't step on the clutch and tried to put it in 5th, and it went right in.
i had a ys1(non lsd) and i put in an A1 trans.
Also while i took out my old trans, the shift linkage bent really badly but only at the end where the shifter connects. Im not sure if this has anything to do with it but thats just more info.
please help!
please help!
Your 5th gear sounds like its stripped out.
what do you mean "a1" trans? whats that out of? If you mean trans from a b18a1, you can take out the 5th gear i believe from the ys1 and put it in there
Is it really possible to drive a car without a 5th gear in a 5spd transmission though?
lol. dude, i bought a jdm y1 tranny w/lsd for dirt that had no 5th gear. come to find out that the guy i bought it off likely botched an ls 5th gear swap. those gears are the closest ratio of any cable trans. i drove with the 4 gears to and from work on the hwy everyday for 3 months. you'll be alright until you get time to pull it out. the 5th gearset is easy to get at once the trans is out
damn haha i thought i was just trippin. well thats some good news i guess lol. did you ever put a 5th gear in or are you still runnin 4 gears?
probably not the same scenario bc way different cars, but on my evo i also bent the little things that connect the cables to the tranny to shift it, i had the same problem i got all gears but 5th unless shut off and sitting still..im currently in the process of getting the new parts but it did the same thing on my car was like putting it into neutral
https://honda-tech.com/forums/acura-integra-6/tranny-overhaul-jdm-itr-final-drive-lsd-install-56k-not-so-much-795700/
Heres a good writeup, theres another one too that i was just reading somewhere on here..
https://honda-tech.com/forums/showthread.php?t=795700
Yeah im about to change my linkage tmrw and see if that works. if not im probably gonna open it up and see whats going on in there.
just make sure you have a nice clean open space and keep all parts in perfect order, laid out exactly as they were removed
i mean i wouldn't think the linkage was a factor until i read this thread saying if the linkage is bent, it could be the culprit. It bent pretty bad to a point where i couldn't bolt the shifter in. and yeah thanks for the tip.
MintyDip
Aug 23, 2001 07:02 AM
[/IMG]
wowwww.
