Best ECU for ITB
Old Jan 24, 2012 | 07:05 PM
Teamdiesel's Avatar
Default Best ECU for ITB
Which standalone has the best features to effectively tune ITB's, especially at idle. I am looking between Hondata S300, AEM, or Neptune RTP.
Old Jan 24, 2012 | 07:12 PM
DDTECH's Avatar
Default Re: Best ECU for ITB
Neptune, unless you're going to a FULL Standalone. IF its a full standalone, i suggest looking into a motec or PROefi
Old Jan 24, 2012 | 07:24 PM
team top secret's Avatar
i was running crome on my stock ITR with twm and its my Daily and it idle like stock tuned at church
Old Jan 24, 2012 | 09:12 PM
DA93teg87's Avatar
EcTune is my favorite, has a straight itb based section to run straight off of tps.
Old Jan 24, 2012 | 09:19 PM
angryhillbilly's Avatar
ITBs can be very tricky to get right. and the way the engine idols and runs can change everyday with different weather and temperature conditions. to get them to run perfectly it will require you to make constant adjustments. you need somthing that alows you to make these adjustments as well as carry multiple maps on hand. thats why i would go with a complete stand alone like the AEM.
Old Jan 24, 2012 | 09:57 PM
Uncle Dave's Avatar
ViPEC also do a plug'n'play for Honda OBD1 or OBD2 its based on a V44 unit.
Old Jan 25, 2012 | 04:17 AM
DDTECH's Avatar
eCtune/Neptune hands down if you're staying on a oem ecu.
If you aren't. ProEFI or motec would be the next choice, even haltech.
Old Jan 25, 2012 | 06:10 AM
92TypeR's Avatar
FSAE
x2
If you are going with a full standalone, I highly recommend ViPEC. The plug-in board is a great option for Hondas since you have a "stock appearing" ECU with a full standalone inside.
Plug-in Boards:
http://www.vi-pec.com/page_files/pluginecu.htm
I am running a V88 in my Supra and the logic capabilities and datalogging GUI is unmatched in its price range.
In terms of ROM editors, either Hondata, Neptune or eCtune can run ITB's well. Any of these can allow you to use TPS% instead of MAP, which will create a more responsive and easier-to-drive car.
Old Jan 25, 2012 | 06:21 AM
mtber's Avatar
All of the systems you mentioned work great.
Old Jan 25, 2012 | 10:58 AM
highboostcivic's Avatar
I was reading an old thread where people were saying that Crome had an option to run ITB's on a map base from idle to a certain point where it then switches over to tps base. They said this gave the best of both worlds, of having a consistent map idle and part throttle, while changing to tps for the rest of the map.
My question is, does this feature really benefit over using 100% TPS, and if so then does Hondata and AEM carry this feature?
Old Jan 25, 2012 | 09:11 PM
mtber's Avatar
http://hondata.com/help/smanager/tun...ghtsub=alpha-n
Old Jan 26, 2012 | 01:19 AM
jdmintegraxsi's Avatar
You could always tap each runner and then run them into a vacuum box. I have been doing that for a few years now on a number of different ITB setups and it works great.
It wasn't my daily but I drove thousands of miles on the street with a vacuum box on 2 different setups, sure it wasn't as smooth as a plenum manifold but it was definitely streetable. It could have been smoother I just decided on a small vacuum box that would easily tuck underneath the throttlebodies.
Old Jan 26, 2012 | 09:36 AM
unusual71's Avatar
Crome works but is very temperamental. This year im probably going eCtune
I used a small vacuum log with MAP sensor and a factory kawasaki TPS with crome free and the car idled perfect and drove almost perfect.
Old Jan 26, 2012 | 10:29 AM
fknfast's Avatar
Originally Posted by ALL M0T0R
eCtune hands down if you're staying on a oem ecu.
thats what i run with no problem on my twm setup!!
axistang
Jan 15, 2004 12:50 PM
CRXBart
Mar 17, 2003 07:43 PM
slowazzhatch
Mar 7, 2003 03:51 PM
scooter
Feb 26, 2002 02:13 PM
IGGY
Jul 19, 2001 06:49 AM
