B16b timing issue
I am stumped and need a little help. I have set my engine to tdc on crank
And lined up my cam pulleys. Now the engine is a ctr b16b in a eg civic running pct
Ecu and a obd1 distributor. (it is not oem) Now my problem is when I try to time it
The engine will stumble under acelaration. There is only one spot I can set it to on the
Whole range of adjustment on the distributor. that spot is almost advanced all the way.
do you guys think it could be my distributor? Thanks in advance for the help.
tcyprusdc2
Apr 4, 2014 10:05 PM
