quicker spool / wastegate
hi
I have a tial wastegate.
I connected the hose from the turbo compressor to the wastegate actuator as usual without any boost controller.
Question is : Instead of not using any boost controller, If I use an EVC, will it help spool quicker ?
Is there anything like that ? I don't think so - but anyway I'll ask..just to make sure..
considering I have witnessed ebay gates leaking at every possible part they could leak from... they can for sure hurt spool.
Running a "ball and spring" type boost controller will give you the best spool possible as it will prevent the wastegate from opening a bit while you are building boost.
By definition, the ball and spring is just reducing "lag" time (aka the time it takes from .1psi of boost to peak), not so much spool as the wastegate should never be opening before you make positive pressure.
hi
As for whether or not it makes a different with an eBay one or not, I can only say, NEVER USE AN EbAY GATE, and you'll be fine.
The answer you're looking for is no, mechanically both a TiAL Wastegate and a cheaper knockoff function in the same manner. A TiAL will not help you reach full boost faster than a cheap knockoff.
However, a TiAL is far more likely to open when you want it to. Not before, not after, and not never like some of the cheaper ebay gates like to do. Stick with your TiAL
turbodan4
Mar 7, 2006 09:09 PM
