how do i know what obd my b18b1 is sorry new to this
Old Jan 23, 2012 | 07:48 PM
jake12ryder's Avatar
Default how do i know what obd my b18b1 is sorry new to this
idk if its obd0, obd1, obd2 please help
Old Jan 23, 2012 | 07:54 PM
88HATCH(:'s Avatar
Default Re: how do i know what obd my b18b1 is sorry new to this
looks to be obd0.
Old Jan 23, 2012 | 07:55 PM
wreckin-rex91's Avatar
It's all in the dizzy! Check your ECU type too ... That makes it easy
Old Jan 23, 2012 | 08:17 PM
alright thanks guys appreciate it
Old Jan 23, 2012 | 08:33 PM
alex14's Avatar
the valve cover is OBD2, if the motor has a vin number on it, its OBD2.
B18b1 was only made in OBD1 and 2, not 0
the dizzy and ECU can all be changed to work with the motor. You can have a motor from the 96+ (obd2) cars and be running obd1 or obd0
If you are asking if your car is set up to be OBD0,1, or 2, then check the ECU.
Old Jan 25, 2012 | 07:12 AM
how can i tell on the ecu... the ecu is a pr4
Old Jan 25, 2012 | 07:20 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Just look at the plugs...
Old Jan 25, 2012 | 07:25 AM
thanks man i will have to check it out when i get off
Old Jan 25, 2012 | 08:28 AM
codybuRr's Avatar
you realize b18a and b18b have the same internals, you can convert up and down between obd0 thru obd2.
its all in the wiring and ecu that you use.
Old Jan 25, 2012 | 08:33 AM
alex14's Avatar
Of coarse.
Old Feb 14, 2014 | 04:31 PM
myownworstenemy's Avatar
i have a b18a1. no sure what obd it uses but i could just use a obd1 harness and and ecu and it'll all work out?
Old Feb 15, 2014 | 06:43 AM
Spug's Avatar
You would need an OBD1 Dizzy and ECU, as well as the ECU jumper harness if you choose to use one.
RageRage
Jun 23, 2014 10:24 AM
brendan427
Oct 16, 2012 10:30 PM
Under_Pressure
Mar 26, 2006 07:34 PM
kool168
Nov 26, 2003 05:13 AM
1hotvtec
Oct 12, 2003 07:29 PM
