Log vs ram manifold low boost on high rev motor
Old Jan 22, 2012 | 06:04 PM
DELshaneSOL's Avatar
Default Log vs ram manifold low boost on high rev motor
Im looking at a revhard log mani or a used ramhorn.
I'm only running 6psi on a stockb16a
With a 50trim turbonetic turbo
I'm not sure if the manifolds would make a huge diff with low hp numbers
Because the b16 revs high I wanna get the ram because it make more power in the higher rpm
Would it make that much of a diff besides looks? Of I went log
Old Jan 22, 2012 | 06:11 PM
TheShodan's Avatar
Moderator
Default Re: Log vs ram manifold low boost on high rev motor
Not for that size turbo. There's no reason to run a full equal length manifold like that for something 49lbs/min. the tubular logs are a nice medium to use (since you have to have a downpipe made for it anyway whether you have a used cast log or not).
Stay simple. especially with a B16 and stock cams. No need to go crazy. you'll do as much top end as the 50 trim you're using will allow, no problem.
Whiterice-gsr's Avatar
i really dont think u would notice a diff in power with that little boost but seriously logs are so ugly and they get all rusty i would buy the ram on looks alone, i do have the ram and i love it.
Old Jan 22, 2012 | 06:14 PM
LightningTeg's Avatar
Community Builder
Old Jan 22, 2012 | 06:50 PM
I do plan on building a block so within a year hope I should have one, should I go log now and ram next year? I could easily sell the manifold, seeing as I'm buying it new and only using it for a year maybe 2 the latest
Old Jan 22, 2012 | 06:59 PM
just buy the ram and be done with it.
Old Jan 22, 2012 | 07:12 PM
00_EKHatch's Avatar
Would you rather spend 5-600 bucks on a manifold (saying you would buy a good one, not Ebay ****.) for 6 bls of boost or 100? That's the question to ask yourself.
Old Jan 22, 2012 | 07:26 PM
I can not find a used log seems only rams
So I was goin off that
Either a used 350-400 ram
Or a new 320-400 log
Old Jan 22, 2012 | 08:45 PM
TheShodan's Avatar
Moderator
try finding a tubular log like this.
Not a cast one like this: from Neukin or Blox or anything of that sort.
InlinePRo is an exception
A "Ramhorn" on a 50trim, just makes no sense unless you really plan to put a much larger turbo later on.
Old Jan 22, 2012 | 09:07 PM
What kind tubular I'm looking between 300-400 Maybe a little more
Old Jan 22, 2012 | 09:26 PM
TheShodan's Avatar
Moderator
Spoolin' performance
Go-autowerks
Best ones to use.. not hard.
Check this person out. Tubular Log manifold from Spoolin' Performance and over 450whp.
https://honda-tech.com/forums/showth...2951496&page=8
Old Jan 22, 2012 | 09:41 PM
http://www.spoolinperformance.com/sp...fold-p-58.html
Only 300 same price as a revhard
http://www.go-autoworks-store.com/go...-manifold.html
Only 295
Nice I think they both use 38mm wastegate and can bolt to a t3/t4 turbo
Just gotta ask which ones better,
Goauto,
Revhard or
SP?
There all about the same price
Old Jan 23, 2012 | 06:02 AM
How are blox manis I found a good price on one
Old Jan 23, 2012 | 07:29 AM
mines13's Avatar
If you can afford a little more money and you still can't decide, go with a Go Autoworks Mini ram.
Old Jan 23, 2012 | 07:43 AM
92frostwhtdb2's Avatar
i just removed my blox manifold in favor of an inline pro ss, being able to compare both side by side i can honestly say there is no comparison period. It might seem like there similar by just comparing pics online but trust me there not, the runners are smaller, horrible merge, less than ample clearance for the dipstick,wastegate issues with the vtec head...for sub 300whp sure its fine but who ever stays at that level.
Old Jan 23, 2012 | 07:45 AM
True but for now lol u selling it
Old Jan 23, 2012 | 07:46 AM
shoot me an offer threw pm
Old Jan 23, 2012 | 07:53 AM
Post pics
Old Jan 23, 2012 | 08:03 AM
i wont have other pics till i get off work
Old Jan 23, 2012 | 08:07 AM
Looks good shape?
How old is it
Any other parts could do a combine price
Old Jan 23, 2012 | 08:16 AM
TheShodan's Avatar
Moderator
I just said not to bother with the Blox/Neukin cast manifolds. I just put the picture up there with that... I JUST DID IT..
Why help when no one is READING
You can't lose between the Go-Autowerks or the Spoolin'. There is no Better in this situation. they both work..
Old Jan 23, 2012 | 08:17 AM
its cast iron so it does have a rust colored look to it now, its almost three years now. the only parts i have to go with are a vband downpipe/up pipe and dumptube, if you need any other info just pm me im not trying spam up the tech forum.
Old Jan 23, 2012 | 08:27 AM
Sorry I seen you did say blox
Is there a dp that will bolt up with the sp mani and wastegate dump
I'm looking into the spoolin one
Or would I have to custom make one or go atmospheric dump
Old Jan 23, 2012 | 08:31 AM
CDecker0218's Avatar
buying new is always a good option but at the same time the ramhorn will save in the long run because lets face it we know 6psi turns into 16psi,26psi, etc
Old Jan 23, 2012 | 08:35 AM
True but imma hold back and stick to 6-7 psi until my block is done
I can do it
lol
