Brian Crower stage 2 or stage 3????
Old Jan 22, 2012 | 05:53 PM
Dom93's Avatar
Default Brian Crower stage 2 or stage 3????
i decided not to go with skunk2 camshafts! i was wanting to know which stage brian crower camshafts i should get for my set up! here is my buiild
ls/vtec:
b18a1 bottom and b16a head
valvetrain: brian crower dual valve springs and steel retainers, blox flat face high compression valves!
bottom end: p30 pistons, stock sleeve and stock bore (11.7:1 compression), stock crank, stock mains and bearings..
miscellaneous: skunk2 intake mani., skunk2 fuel rail, short ram intake, high flow exhaust (full exhaust)..
thank you!
Old Jan 22, 2012 | 06:40 PM
hannslebo's Avatar
Default Re: Brian Crower stage 2 or stage 3????
Stage 2
Seems like stage 3 would be overkill for this setup.
Old Jan 22, 2012 | 06:43 PM
Dom93's Avatar
exactly what i thought to! i just wanted some opinions first! stage three is for like highly build engines, stage two is for like moderate.. i will go with stage two most likely! thank!!!
Old Jan 22, 2012 | 07:12 PM
98civdx's Avatar
Master Detailer
Originally Posted by hannslebo
Stage 2
I was thinking the same, but with that compression he may be ok with the stage 3's.
I would PM a mod and ask to have this thread moved to the allmotor forum, or post a new one in there and keep this one.
Old Jan 22, 2012 | 07:15 PM
Dom93's Avatar
good idea! thanks
Old Jan 23, 2012 | 06:16 AM
kyden's Avatar
if i remember correctly, there are v2v issues with the stage 3.
Old Jan 23, 2012 | 12:53 PM
Dom93's Avatar
i emailed BC and they said stage 2 would be best for my setup and compression...
SoyMilk
13
Apr 26, 2007 05:47 PM
JinteDgraM
Mar 20, 2005 09:06 PM
Fab-Works
Mar 30, 2004 10:10 AM
Joel_MN
13
Sep 11, 2003 08:28 AM
9d9GSR
May 19, 2002 10:06 PM
