Cam gear / Timing help...
Old Jan 22, 2012 | 03:11 PM
Skeero's Avatar
Default Cam gear / Timing help...
I'm not sure how well you can see it.. But the top dots don't point straight up, and the exhaust cam on the left side is sitting at a different angle then the others.. No matter what I do I can't get them to line up.. It's like the right cam sits higher when I have them point straight up. Any help?
Old Jan 22, 2012 | 03:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Cam gear / Timing help...
I don't get it. They are adjustable cam gears. Are you saying you cannot adjust them? Are they supposed to be "straight up" on the gears? The two that are side to side are perfect.
Old Jan 22, 2012 | 03:21 PM
Skeero's Avatar
My bad. I thought they all had to line up? That's what I was asking.
So that does look good?
Old Jan 22, 2012 | 07:53 PM
Skeero's Avatar
Anyone else wanna comment? Just to make sure? First time it jumped time it grinded the cam into the journal and had to have it linebored.. Then I retimed it the other night and started it up and it jumped time again.. Just making sure it's right before I do this **** again..
Old Jan 24, 2012 | 01:59 PM
Skeero's Avatar
Bump.. Don't want to have it out of time. Anyone wanna confirm that's intime?
Thanks.
Old Jan 24, 2012 | 02:07 PM
civicjunkie17's Avatar
It's in time. When you put the belt back on spin the motor over by hand a couple of times so the belt will have even tension all around.
Old Jan 24, 2012 | 02:13 PM
dk=gsr's Avatar
looks good. just put the belt on and do what civicjunkie17 said. you should be fine.
o_Rage_o
Nov 10, 2016 06:32 PM
machine4321
Mar 29, 2005 03:44 PM
DB'd
Mar 6, 2005 06:31 PM
Brewer
Feb 2, 2005 10:48 AM
Brewer
Jan 13, 2004 10:58 AM
