Car Cranks but Wont Start
Old Jan 22, 2012 | 10:49 AM
pyroom's Avatar
Default Car Cranks but Wont Start
The car cranks and sputters like it's trying to start but 95% of the time it won't catch. It originally started doing this last summer only when the engine was warm, but now it doesn't start anytime. I can push start it no problem, but I can't start it with the starter.
The main relay makes 3 clicks, and it doesn't matter what temperature it is outside. The car also sputters sometimes like its running out of gas when I try to accelerate to pass someone on the highway (the RPM needle goes crazy when this happens).
Could it be because I'm burning a lot of oil?
thanks!
Old Jan 22, 2012 | 11:06 AM
singlecamsaint's Avatar
Default Re: Car Cranks but Wont Start
i would like check all your ground wires
Old Jan 22, 2012 | 11:21 AM
Wingman00SI's Avatar
What car is it? and when was the last time you changed your fuel filter? Sounds like you just might need a tune up! spark plugs and wires, cap & rotor and fuel filter..cheap and effective!
Old Jan 22, 2012 | 11:35 AM
pyroom's Avatar
Thanks! It's a 1990 Honda CRX SI.
I just replaced the ground 6 months ago, but I will check that. I was suspecting the fuel filter as well, but I wasn't sure how to check it.
I just need the car to drive 300km home so I can swap out the engine - It burns 1:4 oil to gas, or about 10l every tank lol.
Old Jan 22, 2012 | 12:06 PM
HEADS OR TAILS's Avatar
Have the starter tested and if its good, most likey gonna be ur main relay. I hav 2 extra ones in my rex cuz they burn out over time especially in the summer
Old Jan 22, 2012 | 02:24 PM
pyroom's Avatar
It's a brand new starter, and it doesn't really the the symptoms of a bad main relay. It doesn't matter what temperature it is outside it can only be started by push start. Even before when it was only doing it after the car had been running, it didn't matter if it was only idling for 2 minutes and it was 0 outside or if it was running for 4 hours and it was 50 outside it would still just sputter, and wouldn't start for a good 30 minutes except for in a blue moon it would randomly catch.
Old Jan 22, 2012 | 05:39 PM
Ej1DMJ's Avatar
I'm having the same problem. I have a d16zc sohc cam swap in my 91 hf. It turns over fine but will not turn on. I have no idea what the problem is.
Old Jan 22, 2012 | 05:44 PM
main relays burn out sometimes, ive had a few do it
Old Jan 22, 2012 | 06:54 PM
Usually a faulty main relay will cause a car not to start because of both no spark and no fuel, never heard of a main relay causing are car to run or start like ****???
Old Jan 22, 2012 | 07:01 PM
Check for spark and get your ignition coil and ignition control module tested, and also check for fuel at the fuel rail. If that checks out o.k then check to see if your timing belt is not broken off! Or just take it to your mech..haha
Old Jan 22, 2012 | 08:58 PM
pyroom's Avatar
Yeah when my friends main relay went out his car didn't sputter at all, it would just spin. My car will sputter at 200rpm for as long as 30 seconds on its own but wont catch, except for once in a blue moon when it will start.
I think it's the fuel filter, I found where it is, does anyone know how to get it out?
Old Jan 23, 2012 | 02:57 PM
There's a video on youtube of a 97 prelude that cranks his car over for more than 30-40 seconds and then it finally starts, his problem was the ignition control module in the dizzy. I'll try to find the video again and I'll post the link!
Old Jan 23, 2012 | 08:35 PM
http://www.youtube.com/watch?v=jwaZX...UJg7v89HM8WEBs
Here it is! In his comments he said it ended up being a bad ignition control module in the dizzy.
joehonda1129
Nov 19, 2007 07:53 AM
super jdm yo
Apr 7, 2007 04:10 PM
Accordboy27
Mar 7, 2006 09:56 AM
maxxd97
Apr 23, 2004 06:49 AM
si00000
Nov 1, 2001 06:10 PM
