Function 7 subframe brace
Old Jan 21, 2012 | 07:20 PM
whiteteggy44's Avatar
Default Function 7 subframe brace
Hey guys,
i have a 96 gsr and i was planning on picking up a function 7 subframe brace for it. i was wondering if the tack welded nut in the back of the subframe needed to be knocked off in order to accomidate the brackets for the back of the brace? If any of you guys have had experience with this brace please let me know.
thanks in advance
Old Jan 21, 2012 | 08:12 PM
01oemTeggy's Avatar
Default Re: Function 7 subframe brace
Originally Posted by whiteteggy44
Hey guys,
thanks in advance
Nope. I installed mine myself, took about 3 hrs (including the control arms) and was pretty much plug and play if you have all the necessary parts.
Few pics of my set up.
Old Jan 22, 2012 | 06:58 AM
mike703's Avatar
^^^^ That looks pretty cool with the zigzag all the way across
Old Jan 22, 2012 | 10:10 AM
01oemTeggy's Avatar
Trust me it looks way better in real time. Especially on silver!
Old Jan 22, 2012 | 01:09 PM
Thanks for the info! How do you like the performance? And what sway bar is that?
Old Jan 22, 2012 | 02:19 PM
doood's Avatar
been there done that
i have the same thing on my rsx. gets plenty of bling points. lol
Old Jan 22, 2012 | 02:20 PM
jserman's Avatar
I want this setup... looks SICK
Old Jan 23, 2012 | 12:43 AM
01oemTeggy's Avatar
Thanks! Performance is awesome. It's the usdm 22mm type r sway bar.
You and me both dawg.
Get it, you won't regret it!
Old Jan 23, 2012 | 06:06 AM
bryan24207's Avatar
does anyone know if they sell this set up for a db1? i know alot of manufacturers dont like making parts like this for us old skool guys
Old Jan 23, 2012 | 06:20 AM
donut.'s Avatar
you can't go to the website and find out yourself?
Old Jan 23, 2012 | 06:23 AM
bryan24207's Avatar
guess not, just like i thought they dont make them for that car..
Old Jan 23, 2012 | 01:54 PM
[QUOTE=01oemTeggy;46729385]Thanks! Performance is awesome. It's the usdm 22mm type r sway bar.
Oh I have that one too! Looking forward to pickig up the subframe brace and the lca. What kind of coilovers are you running?
Old Jan 23, 2012 | 07:13 PM
01oemTeggy's Avatar
I'm running the Tien type flex.
Old Jan 23, 2012 | 07:19 PM
01oemTeggy's Avatar
You could always try to see if a set for another car could be compatible?
Old Jan 24, 2012 | 09:57 AM
95 integra's Avatar
On my ASR they stated you needed to remove the OEM nuts welded on the backside, however I found it fit just fine without doing that. Given it added a little bit of difficulty to the install, I didnt like the idea of removing them.
Old Feb 7, 2012 | 12:09 PM
Function7's Avatar
If you have an Integra (or Civic for that matter) with the welded nuts in the subframe, you do not need to knock them out. Skip the backing plate and screw the supplied bolts into the corresponding nuts. You do not need the backing plate if the nuts are there.
-S
Old Feb 7, 2012 | 09:44 PM
01oemTeggy's Avatar
I messaged Function 7 and they said only the lower control arms will fit your car not the brace.
Old Sep 14, 2012 | 02:05 PM
batto24GSR's Avatar
this might sound a little retarded but iv heard that you take out the stock subframe brace and iheard that the function 7 subframe brace mounts to it so i was wandering what you exactly do?
Old Sep 14, 2012 | 08:11 PM
01oemTeggy's Avatar
Only the integra type r came with a subframe brace. Gsr and rest of models dont have one.
Old Sep 15, 2012 | 01:14 PM
batto24GSR's Avatar
i am talking about the piece that the control arms connect to i thought that was just called the stock subframe brace maybe not but whatever it is my question was does it come off? and also does anyone know if i buy the function 7 subframe brace will the progress technology sway bar the mounts directly to the shock bolt on the LCA's will it fit with the function 7 subframe brace on?
Old Sep 15, 2012 | 01:16 PM
01oemTeggy's Avatar
Its the stock subframe, but no brace on it. Thats the purpose of the function 7 brace, it bolts right in when installed properly. And voila, you now have a brace to support and prevent subframe tearout. And no, it will not come off (the subframe)
Old Sep 16, 2012 | 06:34 AM
batto24GSR's Avatar
so does anyone know if i install the function 7 subframe brace will the progress technology sway bar still fit properly
Old Sep 16, 2012 | 11:00 AM
01oemTeggy's Avatar
If its for gsr (assuming cuz ur name) sway bar then yes it will fit.
skylinerb26dett
Suspension & Brakes
Jul 30, 2014 04:23 PM
edinburger
Acura TL, RL & ZDX
27
Sep 3, 2008 08:14 AM
ITR.#1446
Nov 24, 2006 01:57 PM
