need civic ferio specs as reference
so since my car is on blocks right now due to bad rear drums, id figure id take this time to work on my car and redo and upgrade a lot of things. what im looking for is any specs, details, suspension setup for the civic ferio or SiR civic for my 95 coupe. im trying to keep as much on my car original and id like to have the specs from this car so that i can upgrade parts and maybe do a replica of some sorts. anything you guys have will help, so far im googling stuff and whatnot, but i figured one of you guys has something more detailed or maybe you have done a conversion yourself, it would help a lot in my project. this is my first project of this kind so once i get all the kinks and materials sorted out, ill start a build thread
thanks
thanks
Del Sol, Acura Integra, or 99/00 Civic SI rear discs will all swap on. You'll need ebrake cables and 40/40 proportioning valve from the engine bay. Or if you're feeling really frisky, upgrade to a JDM ctr or USDM itr 5 lug.
Depending what trim model that your car is (lx/dx), the front will be a bigger brake upgrade as well.
As far as "suspension", what you're looking for is kinda vague. OEM? Or aftermarket or?
duwa
16
Feb 6, 2014 09:14 AM
govtec
29
Mar 2, 2005 08:43 PM
