ls/vtec build
picked up my b18b1 motor and started to break it down to check out internals. looks pretty good so far, gonna send out to machine shop for hot tank, hone and pressure test block.
my plans for my lsv
b18b1 block
p30 pistons
shotpeen ls rods
stock crank
oem bearings
arp rod bolts
arp head studs
itr oil pump
itr water pump
itr t-belt
GE ls/vtec conversion
ls headgasket
GSR head
ITR valvetrain
gsr cams(hopefully upgrading)
aem cam gears
b18b1 block
p30 pistons
shotpeen ls rods
stock crank
oem bearings
arp rod bolts
arp head studs
itr oil pump
itr water pump
itr t-belt
ls headgasket
GSR head
ITR valvetrain
aem cam gears
yea man same here. i work at honda so i get that employee discount on those p30 pistons and rings lol. im tryin to get about 180hp. from all threads ive read i should be around there. im also lookin into skunk2 intake manifold, rdx injectors, cai, and exhaust obviosly.
cant wait to start buyin things and installing
yea they are smooth and crosshatches are there. im gonna have the machine shop check the cylinders and if they dont need to be bored im gonna keep it at 81mm and get a fresh hone. i wanna order my p30 pistons but i wanna wait till he's done checkin it out. this build is going to be done right the first time
yea absolutely, not tryin to **** **** up lol. im going to order oem main and rod bearings, is it necessary to measure clearances there or ok to put in brand new bearing? with arp main studs and rod bolts of course
definitely check the clearances due to the fact that it tells you to in the Oem service manual with any new part you install. everything you are doing looks great so far! keep up the good work.
keep in mind if you are trying to get the most potential horsepower out of your rotating assembly the looser the better! there are a usually a few size options when using oem bearings. good luck
the best service manual to get is the (dont quote me on this) 92-93 integra because it came with both the b18a and b17vtec engine so it has all the info you will ever need on both ls and gsr engines. hope this helps
