92 dx,cluster lights not illuminating.Already jumped dimmer.
Old Jan 20, 2012 | 07:56 PM
JDMchristian991's Avatar
Default 92 dx,cluster lights not illuminating.Already jumped dimmer.
So,my cluster lights went out the other night.I jumped the black and red dimmer wires together and everything was fine.
Tonight on the way home they went out again.The cluster functions fine,just doesn't illuminate.
I've checked every fuse under the dash and under the hood,all is well.I replaced any of them it could be just in case and no change.
What could this possibly be now?I'm a tad lost at the moment.
Old Jan 20, 2012 | 08:03 PM
Former User's Avatar
Default Re: 92 dx,cluster lights not illuminating.Already jumped dimmer.
Recheck 10A dash fuse 19.
Do the taillights and parking lights work?
Old Jan 20, 2012 | 08:21 PM
Yes they do,everything works as it should other then the fact it will not illuminate.
Old Jan 20, 2012 | 09:09 PM
Test the red wire in the dimmer connector for battery voltage to body ground.
Test the black ground wire in the dimmer connector for continuity to body ground.
Old Feb 6, 2012 | 10:09 AM
Saggio's Avatar
Curious if you fixed this. I'm having the same issue.
Old Feb 6, 2012 | 03:20 PM
jzicc86's Avatar
i got the same problem any luck yet?
Old Feb 7, 2012 | 04:29 AM
Saggio's Avatar
I jumped red to black on the dimmer connector and now they come on with my parking lights. Must be the dimmer. I'll leave it as is for now.
kwae
11
Feb 13, 2014 07:51 AM
imptricer
13
Nov 22, 2012 07:47 PM
ed2
Jul 5, 2010 11:38 AM
boost and bass
Dec 3, 2009 04:41 PM
JasonYo
Aug 16, 2009 06:32 PM
