1996 Civic interior water leak
Old Jan 20, 2012 | 04:21 PM
mcd7's Avatar
Default 1996 Civic interior water leak
The passenger side floor is getting wet after the car is parked for a few days. I can't seem to identify where the water might be coming from. I ran water over the passenger door and saw now water intruding. I do not have a sunroof so that possibility is ruled out. Any other ideas as to where I can look?
Old Jan 20, 2012 | 04:39 PM
ChristianL's Avatar
Default Re: 1996 Civic interior water leak
Have you had the a/c on recently? If so, the drain on the box that collects condensate water might be clogged, and spilling the collected water into the footwell (especially if it's full and you're parking on a hill). It's located in the passenger footwell near the firewall.
Sounds dumb, but might be worth checking out.
Old Jan 20, 2012 | 05:24 PM
EJ8_Man's Avatar
I've got a very similar leak right above the ECU. Mine however is the windshield
Old Jan 20, 2012 | 06:46 PM
HONDAPARTSMANMIKE's Avatar
I think you might have a leaking windshield. Is the windshield original?
Old Jan 20, 2012 | 10:37 PM
EL Vap133's Avatar
Sit inside and have someone run a water hose on the outside.
Old Jan 21, 2012 | 04:49 AM
axis11's Avatar
x2
Old Jan 21, 2012 | 11:33 AM
ej1bmx's Avatar
I had a similar issue in my 95 sedan and traced my issue to old/cracked/weathered seam sealer near where the hood hinge is located. Like said above, remove the carpet on that side and stick your head up there with a flash light and it should be somewhat easy to trace where the water is coming from!
Creature1
Honda Civic (2001 - 2005)
May 5, 2014 10:13 AM
bad 91 teg
33
Oct 1, 2011 02:34 PM
dlenoxx
Dec 2, 2010 12:05 PM
blaisepascal
Oct 15, 2004 10:32 AM
pradeepa
Apr 12, 2004 10:31 AM
