Oil pump
Old Jan 20, 2012 | 02:33 PM
brad22486's Avatar
Default Oil pump
Ok just ordered my b18b and need to know how to change oil pump because im putting it in a 96 teg. Any help is appreciated. Thanks
Old Jan 20, 2012 | 03:03 PM
DirtyDA9's Avatar
Default Re: Oil pump
With the engine in or out of the car?
Old Jan 21, 2012 | 06:29 AM
brad22486's Avatar
out
Old Jan 21, 2012 | 07:17 AM
Whiterice-gsr's Avatar
it'll be sweet to do while the motors out, pull the pan and timing belt and gears might as well replace the belt while your there if it shows any sign of wear at all.
Old Jan 21, 2012 | 07:24 AM
scratch the gears u dont need to take those off my bad. 4 bolts on the pick up tube and 4 on the pump really straight forward, dont forget to use some sealant on the pump housing to block surface when u put it back on or it will leak
caliskier
Apr 9, 2012 01:05 PM
medic4.life
Jul 16, 2007 08:02 PM
idriveadelsol7
25
Dec 9, 2005 08:47 PM
