oil pump... yay or nay?
does the oil pump ever need a change? i'm doing my timing belt and water pump... and would like to know if i should or need to change the oil pump.
Re: oil pump... yay or nay? (******)
jdm d15b.... so i have no idea. barely got the thing put in so i have no idea upon mileage. i figure since i'll be doing all of that.. i should just get it done too
Re: oil pump... yay or nay? (idriveadelsol7)
Yes, change the oil pump. It's the heart of your engine...literally...not replacing it is just being cheap and lazy.
I bought mine from Showcase Honda, and paid 190 shipped for my H22 pump brand new...dealer wanted $250 bucks!
Re: oil pump... yay or nay? (O RLY)
Sounds like it's more of a matter of preference than anything else. If you've got the money to spend, go ahead and replace it I guess.
Re: oil pump... yay or nay? (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">I think it's overkill, but it is his preference.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">If you say that, then I would recommend changing out your entire distributor assembly, they're only $180 and I've actually had a distributor bearing burn up and strand me in the middle of nowhere....there is a large list of $120 items you could change out just to be sure nothing major happens.
Your oil pump is far more likely to die than your dizzy will. The oil pump is recommended to be changed @ 90-105k miles. Its not overkill, its very smart to follow what Honda says.
It's almost hypocritical to say that its overkill to replace the oil pump but not the water pump. They have the same maintenance schedule and they're both as likely to die. They're both vital to the engine life. Do you replace your water pumps @ 200k also? It sounds like you wouldnt even make it to 200k.
If you burn a dizzy, you buy a new one, you'll know its bad because your car wont work.
If you blow an oil pump you'll be buying a new engine.
Re: oil pump... yay or nay? (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">
Oil pumps are not a maintenance item. They do go bad sometimes, but most should last the life of the engine.
i use some 10w oil and in the morning ( kind a 10 grades celsius ) when i start the engine , oil light stays on about 5 seconds and than it goes off
bad pump ?
bad pump ?
Re: (cioli)
Why is this thread still even active. You're right, let him do what he wants. I mean, I've seen people rebuild engines, making sure they bought ARP head and main studs for a 250 whp engine, which aren't even necessary, and not replace the oil pump. Now only one of the engines actually blew up, and it may not have been an oil pump. But it's much nicer to just drive the car knowing you have a brand new OEM, Honda guaranteed, oil pump in your motor. You'll probably be fine without one. Replacing it is just smart, that's all. If you're concerned about dumping $120 bucks into a Honda motor for an oil pump, you don't deserve a quick motor to begin with.
Re: (cioli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cioli »</TD></TR><TR><TD CLASS="quote">i use some 10w oil and in the morning ( kind a 10 grades celsius ) when i start the engine , oil light stays on about 5 seconds and than it goes off
bad pump ? </TD></TR></TABLE>
Most likely. I had a VW that would do that, and it turned out to be the pump.
B A N N E D
Re: (O RLY)
nicely said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O RLY »</TD></TR><TR><TD CLASS="quote">Why is this thread still even active. You're right, let him do what he wants. I mean, I've seen people rebuild engines, making sure they bought ARP head and main studs for a 250 whp engine, which aren't even necessary, and not replace the oil pump. Now only one of the engines actually blew up, and it may not have been an oil pump. But it's much nicer to just drive the car knowing you have a brand new OEM, Honda guaranteed, oil pump in your motor. You'll probably be fine without one. Replacing it is just smart, that's all. If you're concerned about dumping $120 bucks into a Honda motor for an oil pump, you don't deserve a quick motor to begin with.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">Most likely. I had a VW that would do that, and it turned out to be the pump. </TD></TR></TABLE> same with me now i am paying the price.
Solbros Owns Me
you're retarded...to put it bluntly. I have never seen a Honda come through the shop with a bad oil pump. BUT, I always see dizzy's on cars making nasty noises because of shot bearings. Have you ever seen what a siezed dizzy can do to an engine?? It will stop the cam from moving, causing the t-belt to skip, and what do you know, bent valves. It is much more likely for this to happen than anything with the oil pump.
Oil pumps go bad usually because of foreign objects...too much gasket maker, etc.
Replacing the oil pump on a good running engine is stupid unless you have low oil pressue. WHy not buy a 20 dollar gauge and see what your oil pressure is??? Cheaper, you see what shape the engine is in, and you're good to go!
Re: oil pump... yay or nay? (Evs-One)
Please dont turn this into a pissing match like almost every fuel filter post I see you going bezerk in. </TD></TR></TABLE>
haha you still remember that? I guess i pissed off more people than i thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">you're retarded...to put it bluntly. I have never seen a Honda come through the shop with a bad oil pump.</TD></TR></TABLE>
I'm retarded because in your one shop amonst THOUSANDS of shops, you havent seen a bad oil pump....A bad dizzy will usually have some tale tell signs of replacement, whereas oil pumps seem to go in the worst possible situations (i.e. in v-tec @ 8k ). So, if oil pumps dont go bad why dont you talk to Kaoss_11 about that, im sure he'll let you know. I'd rather have bent valves than a seized block. Either way, it's a little harsh to call me a retard because of preference. Calm yourself.
Solbros Owns Me
oh, I'm calm. Go to your local Honda parts counter and ask how many Civic oil pumps they've sold this year compared to distributors....argument over
B A N N E D
To tell you the truth it can go both ways. Everyone knows that a dizzy may go out on a honda any day of the week but it is a little more rare to see an oil pump go out. The funny thing is that my oil pump just fucked up on me so there was no way of me knowing but just 6 months prior when i was building it, it was just fine. I blame the cams being to much for the oil pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">oh, I'm calm. Go to your local Honda parts counter and ask how many Civic oil pumps they've sold this year compared to distributors....argument over</TD></TR></TABLE>
It was never an argument to begin with, despite your effort. I still prescribe to changing my oil pump when I change the water pump. Regardless of what you think I would say more people buy oil pumps than they do dizzys because of the fact that its recommended service. Its bundled into the 90k service at a LOT of different mechanics. I'm not going to bother with calling my local Honda places because I dont really care who's right.
Maybe its just because your Captain Fancy-Pants-Knowitall or maybe because I'm so obviously retarded but if people are so up in arms over this guy replacing the oil pump, why hasnt anyone said anything about the water pump? I would think those 2 are just as likely to go out. Also, is a dizzy part of the recommended service? @ what mileage would you guys recommend replacing the dizzy?
