d16y7 Won't Start,Please Help
Hi all, I'm new here. I'm from Bulgaria and here in our Honda community / forum I can not find a solution to my problem. Engine is d16y7 on six gen. us coupe 1996 year. The problem is that a few days started very hard in the morning.In the night temperature reaches -20 but it is always started. Two days ago, the engine totally dead. The car has a fuel pump working, spark of all four candles,compression 10 on all cylinders,main relay - checked (working),starter - (working),bobbin. Now I do not know what to do.
Spinning in my head things that can be a sensor under the distributor for automatic choke,commuter on distributor. I wait for your help! Thanks. Greeting Giorgio from Bulgaria
what does the car do??? like does it make a clicking noise when u open the switch ignition switch???? have u check the battery if it has full charge also the alternator if not take them to a shop to be tested for full charge...
The spark color is yellow...Can any of the sensors that tell the ECU to launch the automatic choke simply does not work...
No CEL errors...timing belt is checked, not jumped teeth.
for a coil.....yesterday checked resistance and it was the norm. \
http://imageshack.us/photo/my-images...mpsensors.jpg/
I think for red sensor can work bad...
1) Some bad coils falsely test fine by resistance.
2) Also test the ICM.
3) Measure voltage at the Blk/Yel wire attached to the coil and ICM with the key in ON(II).
I've measured the voltage at the (+) of the coil using the battery (-) for ground and it show 12.4 V with the key on II position, and 0 V with the key on I position. Between the (+) and (-) on the coil shows 0 V. I'm getting 12.4 only if I use for ground the negative terminal of the battery or engine ground points.
Today after the change of ignition coil with new and icm(hitachi E-12 302) did not start. My original icm is number is (Е-12-303)...the difference is only in the metal plate which attached.. I do not know what to look for, I'm so confused now ...
that747guy
34
Jan 2, 2021 09:27 PM
SOHC_civic_si
36
May 21, 2008 07:31 PM
jdmmostwanted
12
Feb 8, 2008 05:08 AM
LSegHatchy
Aug 26, 2004 08:22 AM
Regards...
