What B series pistons do you use?
So im planning a new build for road racing and was wandering what pistons you guys use such as casted or forged and what compression. I talked to a bunch of people and the recamended casted but I like to hear what you guys run.
1) Any specific class/series you're looking to race in?
a) If yes, build your engine to the rules and that'll dictate what pistons you're allowed to use
and
2) What type of engines will you be using/allowed to use as per rules? N/A or forced induced? (Again, dependent on what ruleset/series/class you'll be competing in)
Not trying to be a d*ck however if you want an honest (and informed answer) then you are going to need provide a lot more detailed information. Such as, is the is a going to be N/A or boosted? Strictly a track car or dd too? If it is strictly a track car which sanctioning body? Which class? Is this more of a manufacturer question i.e. Wiseco vs Nippon, etc?
The more you give us the better your response will be.
A lot of variables here like mentioned.
Im currently running oem p30s putting me right at the compression limit (11.0:1) for my class.
Well right now i have a H1 specific B16. but now i just wanna do mean ls/v for time attack. I would Love to run forged but i dont know if that would be the best option for for that. Sorry for the vauge question! the car will only be drivin to the track and on the track and thats it.
or just race in H1 since you already have an engine for it.
That information helps. Is there a specific reason for the piston change or are you simply doing a ring and bearing? The reason I ask is that most forged pistons require different clearances than cast models. If you are going perform a full rebuild (bore, hone, balance, etc) then a piston change isn't that big of a deal because your machine shop would be able to set the clearances to the piston manufacturers specifications. However if you are simply doing a ring and bearing and want to replace the pistons while you're there swapping one for the other would be un-wise.
There is a whole thread on the advantages of one over the other here: https://honda-tech.com/forums/all-motor-naturally-aspirated-44/forged-pistons-vs-cast-pistons-2721867/ and here: https://honda-tech.com/forums/all-motor-naturally-aspirated-44/my-k20-rebuild-2427270/
Lots of information and opinions to go through. Please keep up the updates!
When I was all motor I used to run Endyn Rollerwave's which are basically just a custom-spec Wiseco piston. I still run Wiseco in my turbo motor as well and have always had good luck with them.
admassa beautiful link thank you! i cantacted lary and ENDYNE and they no longer sell rollerwaves to the public they now only come in engines they build. So have been reading on Supertech's forged piston and I think I might go that route because they are made by Mahle.
I have some Pro 1's laying around and a ENDYNE ported head so I might do a 13:1 LS/V. My only worry is with the temps and Extended revs the engine will see. ie... 20 minute heats
Glad I could help albeit on the backs of others hard work! Keep us up on what you do and please heed the advice given by vtecjj (2 time Honda-Challenge champ!) & dirty19, build to the class you may want to race in. If you go too crazy and then later on down the road want to try an H1 or H2 race then your motor may end up being illegal.
Good luck!
Good luck!
Supertech Pistons. Best bang for the buck for a fully coated Forged piston. Have Eagle rods connected to them as well which are PLENTY for all motor setups.
cast pistons + extended heat = not reliable. There is a reason for forged pistons and it isn't because they are shiny and more expensive that makes them better.
froggy123
Nov 11, 2012 04:48 PM
EngineNoO9
Honda Motorcycles
17
Nov 15, 2007 12:19 PM
