What temp activates radiator fan?
Old Jan 19, 2012 | 05:48 PM
wakawu's Avatar
Default What temp activates radiator fan?
Recently got a 98 Civic DX replaced the head gasket, radiator because the plastic was pretty much shattered, distributor, etc. I noticed the fan not coming on after idling for quite some time even though the temp gauge was midway or slightly less. I have a cheap obd2 scanner tool and it displayed engine temp around 136*F I have no idea what the temp setting is for the radiator switch to activate..
The fans do work when hard wired directly to the battery. I'm concerned because I'm pretty sure the head gasket and radiator went on the previous owner due to overheating
Old Jan 19, 2012 | 05:54 PM
Former User's Avatar
Default Re: What temp activates radiator fan?
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Jan 19, 2012 | 05:55 PM
ofthesun94's Avatar
the temperature for the motor should be between 140 to 180 degrees you will be fine at 136
Old Jan 19, 2012 | 06:02 PM
No, that's not right. This is from the service manual:
But back on track, it sounds like there's air in the cooling system. Do the bleed.
Old Jan 19, 2012 | 06:35 PM
Humphrizzle's Avatar
usually when the thermostat opens, the fan comes on.
Old Jan 19, 2012 | 07:52 PM
apexi_rsx's Avatar
sensor by the thermostat is where the fan get signal to turn on and off.
Old Jan 20, 2012 | 07:11 AM
motegicivic's Avatar
Typically the fan comes on about 205 F or so, most likely at idle if the car is running for awhile, esp stop and go.
The normal operating temp is about 170 degrees, after the thermostat opens.
Old Jan 20, 2012 | 07:22 AM
Where do you get your information?
Old Jan 20, 2012 | 07:28 AM
I ran a scan gauge on my car watched in idle as it approached 205 the fan kicked on.
Watched the temp as driving normal temp was 170ish. My ex has a 170 temp thermostat.
This is going by experience.
Old Jan 20, 2012 | 07:41 AM
Here's how you should edit your original post:
Typically my fan comes on about 205 F or so, most likely at idle if the car is running for awhile, esp stop and go.
My normal operating temp is about 170 degrees, after the thermostat opens.
The point is that you have posted your personal experience, but there is actually a range of normal temperatures, depending on car and conditions. For example, my engines when warmed up run in the range of 195-204F, depending on the conditions.
Old Jan 20, 2012 | 11:54 AM
NewtoCivics's Avatar
Air in the line seems like the most logical explanation. I had this same problem in my GMC Truck. I bled the lines, as the diagram Ron showed, and it worked fine. Another problem could obviously be leaks. If the thermostat isn't stuck(and it's not according to your findings) check all your hoses and also check your water pump. I haven't had the pleasure of changing a water pump on any hondas but it was fairly simple on my truck. Good luck none the less!
1mugencrx
Jan 6, 2014 06:07 AM
JH4DB858
Jan 10, 2012 07:32 PM
408maro
25
Oct 19, 2010 06:42 PM
landon.alder
14
Aug 6, 2009 02:53 PM
mika
Aug 8, 2004 05:00 PM
