95 B18C1 Weak compression
Old Jan 19, 2012 | 08:35 AM
Solster's Avatar
Default 95 B18C1 Weak compression
Ok so i have a B18C1 in my teg and it has Very low Comp on #2 and #3 spark plugs are oil fowled.
now is there any thing common with any of the B series that will cause this.
All I can think of is broken rings as I still have good comp on the other two.
compression test was as fallows
#1 = 185 PSI
#2 = 30 PSI
#3 = 35 PSI
#4 = 195 PSI
Now there is alot of oil in #2 and #3 so i'm wandering of it's a broken pistons
I know the head gasket is good as i'm not getting and coolant in the oil and i'm not loosing any eather also the oil is still oil and not a milk shake.
i'm gooing to pull the head soon and i have a Full gasket set for the motor and a set
of rings and bearings for it i just wanted to know if i should start looking for new pistons
Old Jan 19, 2012 | 10:45 AM
DirtyDA9's Avatar
Default Re: 95 B18C1 Weak compression
Do a leak down test, then you will know what caused it. I say bad valve seats.
Old Jan 19, 2012 | 07:24 PM
el crapitan's Avatar
try a wet compression test. see if it yields higher numbers.
but because the cylinders are adjacent, i'd say a warped/cracked head is a likely cause. it is not definitive that a breached head gasket will cause a loss of coolant or a mix of coolant and oil. although honda heads aren't particularly synonymous with cracking, it is possible. could be a crack between the 2 combustion chambers.
Old Jan 19, 2012 | 07:27 PM
and if the piston(s) were cracked, you'd likely have a dead hole. also, it probably wouldn't happen to 2 of them at the same time
Old Jan 21, 2012 | 11:53 PM
Solster's Avatar
ok well a wet test is point less as there is a definat sign of oil with the plugs out.
also putting a plug in #2 and the tester in #3 didn't yeld any higher of a reading.
and yes i know with the valve timing just putting in a plug wont tell if the heads craked or warped.
but 90% of the time when i was working if it was a cracked head there would be a +5~15 lb of compression from the added resistance.
i'll do a vac test monday and hopfully get the head off at the same time and i'll update what i find.
im willing to spend some money getting it back on the road but a Neew Head or block and im done with it. i'll rebiuld a head but if it's cracked to hell with it.
Old Jan 22, 2012 | 12:02 AM
yea, i guess a wet test is pointless. i'm certain it'll be an issue with the head though, as the affected cylinders are adjacent. although the deck could also be warped. if you wanna know if it's cracked, you'll need to pull it off and have it fluxed, or whatever method the shop prefers. either way, the heads gonna need to come off to check for trueness of the deck and head. also for cracks
Old Jan 22, 2012 | 12:05 AM
tbh though, it's more likely just warped. at either mating surface
Old Jan 22, 2012 | 12:09 AM
Solster's Avatar
well i'm hopping it's just warped but the local shop told me for $75 if all i need is the head
shaved and a valve job i can use the shop and he will teach me how to use the tools
for all the testing and such so i can do all my own work
Old Jan 22, 2012 | 12:17 AM
Solster's Avatar
eather way i think i'm going to put in new rings i have a Full gasket kit for the motor so i'm
just goin to drop the oil pan and push out the piston and rering them.
also will give me a chance to see how the bearings look on the rods and if there bad i'll pull
the block out and do the mains as well.
i'm not looking to race the thing just need a DD for me and my kids.
Old Jan 22, 2012 | 12:39 AM
tbh, i doubt i'd go that far even. i'd probably just pull the head, have it checked for cracks, pressure test, if good, resurface and deck the block
up to you if wanna start pullin the block apart. if you do, be sure to check the cylinders for out of round too. may as well give them a hone as well.
Old Jan 22, 2012 | 02:40 AM
Solster's Avatar
if i pull the pistons it getting honed
Old Jan 22, 2012 | 07:17 AM
DirtyDA9's Avatar
I'm guessing you still haven't done a leak-down test?
Old Jan 26, 2012 | 01:29 AM
Solster's Avatar
ok so the heads off and looks like burnt valves.
so $275 and the Machine shop and ill be back together.
i have also decided to do the rings sence im already here and i have the parts.
Old Jan 26, 2012 | 04:25 PM
Dc4LsTeG's Avatar
EK9
Is that a piece missing from your valve?
Old Jan 26, 2012 | 06:31 PM
Solster's Avatar
yes it is.
thay my friend is what you call a Burnt valve
most likely started as a small little leaking spot but as the engine runs it's like taking a blow tourch to them every time the cylender fires.
Old Jan 26, 2012 | 07:29 PM
that's also why it's a good idea to periodically check your valve lash. as it is a major contributor to burnt exhaust valves
pretty surprised you were able to get any compression out of those cylinders.
how did the piston heads look? any of that debris pinging around in there? cylinders look unscathed?
Old Jan 27, 2012 | 12:10 AM
Solster's Avatar
The rest looks fine but i'm going to do the rings and rod bearings with it all torn down as far as it is.
Keep in mind the only time all the valves are closed at the same time is the compression stroke so
any melted slag from the valves would have been blowen into the exhast manifold
Old Feb 7, 2012 | 09:34 PM
Solster's Avatar
Ok so i haven't posted back for a little bit so here it is.
got the head back and all the main bearings installed and every thing back together.
i'll post Pix of the parts i pulled out later but lets just say it looked like the motor was biuld with used parts from god knows where.
I even took the time to saolder in connectors for the O2, Dissy and Vtec that the last ******* had butt connected directly to the harnnes.
When i was waiting for the head to get done and the parts to come in the mail i worked on repairing the interior.
All i have left to do is finish the rewirering of the passenger head light find some H4H bulbs raise the car up about 2"~ 2 1/2" and figure out where the hell the water in the trunk is coming from and i'm set.
Old Feb 21, 2013 | 12:24 AM
da9bigboi's Avatar
Hey did you ever get this running.
GSRicer
Jun 26, 2009 05:11 PM
efcivic757
15
Apr 14, 2005 06:27 PM
GSR4door1
Mar 31, 2004 06:39 PM
EARLdaSQUIRREL
10
Aug 8, 2003 02:43 PM
Jet Black
Jul 22, 2003 07:41 AM
