Bad fuel pump????
Old Jan 18, 2012 | 01:28 PM
b20vteclsintegra's Avatar
Default Bad fuel pump????
So I have a 95 integra with a lsvtec motor in it it wont go about 3,200K if you go more then 30% throttle but if your easy on throttle it clambs fine. Im lost cause i checked the icm and coil they are fine. No check engine light on at all. also when the car is cold it dies and even when its warm the idel is bad and low. If someone can give me some ideas where to start looking
Old Jan 18, 2012 | 03:49 PM
Default Re: Bad fuel pump????
TTT
Old Jan 18, 2012 | 04:04 PM
Dc4LsTeG's Avatar
EK9
Are you sure your cel works?does it light up when you first turn your key?sounds like your in limp mode
Old Jan 18, 2012 | 06:01 PM
shogun88's Avatar
I agree sounds like it could be in limp mode, add some motor oil to it i had a 88 camaro a while ago and it went into limp mode then i just added some oil to it and it ran great but now i own a DA and i love it!
Old Jan 19, 2012 | 11:35 AM
Yes the cel works fine. And the oil is fine too. I dont have any clue as to what the heck is going on with it
Old Jan 19, 2012 | 11:42 AM
Dc4LsTeG's Avatar
EK9
What ecu are you using?
Old Jan 19, 2012 | 11:47 AM
Chipped p28
Old Jan 20, 2012 | 11:35 AM
TTT
billy hoang
12
Apr 11, 2009 07:54 AM
wifesaynogo
Sep 18, 2006 05:42 AM
95accordh22a
Aug 30, 2005 04:29 PM
01IntegraSE
Mar 20, 2003 05:56 PM
