Will b16 head studs be long enough on ls/v
Hello. Im building an ls vtec but I'm wanting to know what head studs I should get. My buddy has some b16 arp head studs but idk if they will be long enough of not. Can someone please help me?
Since it's your buddy then test fit them to see if they are long enough. I reused my ls studs on my ls/v and made spacers for the two in the center that were longer. I'm not telling you to use them I'm just saying test fit them. I believe b16 is the same length as the ls studs with the exception of the longer 2. Gsr studs is what everyone uses for ls/v though.
That answer is YES, because you're going by the Deck of the block not just the head. USE GS-R Head studs..
Here.. To answer ALL QUESTIONS:
How to build the most reliable LS/VTEC
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
These links are selling GSR and TYPE-R as the same, and shouldn't b16's and type-r's be the same?
http://www.ipgparts.net/store/ARP-He...5-Engines.html
http://www.jhpusa.com/store/pc/viewP...idcategory=382
But then other sources say
GSR/TYPER headstud length, kit 208-4303 - 7.250”, 184.15mm
B16 headstud length, kit 208-4601 - 7.100", 180.34mm
The difference in length is due to the deck height of the block. It makes absolutely zero difference which B VTEC head you are using.
The JHPUSA link is saying the same thing the rest of us are. B16 is DIFFERENT due to the DECK HEIGHT than GS-R or TYPE R (which are the same). You don't go by the head, you go by the BLOCK when configuring.
almostjdmeg
Jan 3, 2009 07:41 AM
