obd1 b16a swap on 1997 civic dx
Old Jan 18, 2012 | 01:48 AM
qpzm12's Avatar
Icon2 obd1 b16a swap on 1997 civic dx
there is alot of write ups on this topic but they do not answer my question. i have a obd1 jdm b16 swap in 1997 civic dx. kept my d16y7 wiring harness. made the iacv 2 wire plug, and re pinned the wire on ecu plug. car starts fine. car revs up with obd2a ecu but when i put on p28 with jumper harness.. it runs like crap.. wont even rev up. do i need the ckf by pass trick if im running p28 obd1 to obd2a on jdm b16 motor?? is there any other wiring i need to manually change either on ecu plugs or engine bay harness when using the d16y7 wiring harness, beside vtec wires, knock sensor, iacv ??? any help is greatly appreciated , i would like to get car running asap
Old Jan 18, 2012 | 08:07 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd1 b16a swap on 1997 civic dx
Does it throw any codes with either ECUs? No CKF needed for P28
Old Jan 18, 2012 | 08:16 AM
kyden's Avatar
do you have the right map on the p28?
90civicbns
Jun 26, 2013 10:59 AM
Jeff
Aug 5, 2005 08:31 AM
ensracer
Jul 7, 2005 02:05 AM
pane93civhb
Feb 15, 2005 12:35 PM
CRAYZBOYZS
Jul 18, 2002 12:55 PM
