95 Honda del sol roof leak?
I did until someone i knew gave me brand new oem seals. If you look under your seal in the front on both passenger and driver cause mine used to leak right by the visor. If you pull the seal up you might see two rust holes and thats the reason why water is getting through and leaking. What i did was fill the rust holes with silicone so water cant get passed. Works great and i havent had a problem lol
Jedi_Sol
14
Nov 14, 2003 12:49 PM
