turbo stock h22????
OK hears the deal. i have a civic hatch with a stock h224, i also have a full greddy turbo kit from my old single cam laying around. now would it be safe for me to run 7lb of boost not opening up the motor to put new head gasket and add a block guard? not really being cheap but a always believed that honda's always seem to run best un opened. like i said i have a full greddy kit truly only need the manifold...
a block guard is junk 7 psi on what turbo... just cause its a greddy doesn't tell us the size
injectors and fuel pump? do u have a tuner u are going to take it to?
not opening the motor?? i don't even understand what this means opening the motor up doesn't mean sh*t unless ur a crappy mechanic...
I would not put a Greddy kit sized for a D or B series on an H-motor. You'll probably have it spooled up at idle. H-series is obviously bigger. You'll need bigger everything to go on this engine. Don't think for one second you can move kits around like you can on a D and B series and only swap out a manifold.
Un-opened is poor slang for stock. Your belief is totally without merit.
Generally speaking h22's are plenty strong. There's been plenty of people who've made 400+whp on stock blocks with no real issues. Moving this to the FI forum.
t28 Garrett
440 injectors already have the 255 wel-bro
i have a tuner who knows what he is doing
not opening it because if dose not make sense to open the motor and not just do a full rebuild well it out and apart..
call me a crappy machanic or not, at 18 years old i built a 11 second hatch by my self thanks though
t28 Garrett
^^ i did the same thing with my rex.. i could only work on it on my lunch breaks.. and after the shop closed... so me and my buddy would go up there at like 11 and come home at like 3.. haha but mine never reached 11's though
you have a pic??
t28 Garrett
Honestly, its best to look to a completely different exhaust manifold, turbo, downpipe and wastegate to start off with here. Even on the stock engine.
It never was. But from what I see, the OP is looking at the turbine housing of the D-series kit that he had. As I stated, the GReddy kit for the D-series contained a HYBRID Garrett/Mitsubishi turbocharger (Mitsu compressor wheel, compressor housing, backplate), while the turbine was from a Garrett (Garrett turbine housing, T25 flanging system and turbine wheel.)
t28 Garrett
but when u turbo ur car u have to put a new headgaset along with ARP headstuds or ur gonna have headlift
BUT with a safe tune on a healthy motor (Studs and a gasket ) Ive seen more than a few LAST at around 400+ Wheel (Done so personaly) The good manifold (an efficient one) and IMO a T4 hotside will help keep reversion and egt issues from popping up...
Only issues Ive seen with doing so were log manifolds on turbos too small running **** tons of boost to get there.
Hs really dont like restrictive hotsides at all. If a t3 housing Id want nothing smaller than a .82. In a T4 Nothing smaller than a .68.
400 is totally doable on a well tuned healthy motor ... WIth some longetivity if you take care of the engine :O)
Waking this thread up. I'm trying to get a nice turbo that spools very quickly. I don't need 350hp. I really don't even need 300. I just want a quick spool at low rpms.
I've been readying a lot of threads. What's the smallest t3/t4 that would help me
axhieve this?
axhieve this?
99_red_si
Feb 22, 2008 05:21 PM
CivicGSR225
Jun 17, 2004 11:54 AM
