HELP!
Old Jan 16, 2012 | 09:01 AM
89CRXSi_24's Avatar
Icon6 HELP!
ok, so im having a problem and cant seem to figure it out. when i try to start my crx, i turn the key, it starts then i let go of the key and it cuts off, but if you turn the key and keep holding it over for like 20 to 30 sec it will stay started, what could cause this? im kinda thinking solenoid, but not sure
Old Jan 16, 2012 | 10:05 AM
90civic-ZC's Avatar
Default Re: HELP!
Sounds like the ignition switch......does it turn back off if you jiggle the key while it's on?
Old Jan 16, 2012 | 10:06 AM
linkedtamiya's Avatar
Default Re: HELP!
im thinking the ingnition too
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: HELP!
There are way too many variables to be able to determine the problem from the vague description. Why would you think it's a solenoid? If the car is turning over then obviously the starter works. There could be a lot of things going on so check your fuel, spark, and compression and go from there.
You could also, check the ignition switch first as stated by others.
Old Jan 16, 2012 | 01:04 PM
floodx4's Avatar
Default Re: HELP!
Sounds like its in the ignition to me...from the way I read the OP. If your issue is "The car only stays running when I hold the key in the start position" (which is how I read it), then I would start troubleshooting at the ignition switch.
Old Jan 16, 2012 | 01:11 PM
Dioxine's Avatar
Default Re: HELP!
x2
Old Jan 21, 2012 | 11:01 AM
89CRXSi_24's Avatar
Default Re: HELP!
sorry for the vague description. when i hold the key over for 20 to 30 seconds, and then let go of the key it will usually start. the fuel, spark and compression are fine. how to i check the ignition switch?
Old Jan 21, 2012 | 11:07 AM
singlecamsaint's Avatar
Default Re: HELP!
its the switch it has a mechanical part and a electrical part, the electrical part sounds likes it bad for the on position. ive had this happen on a few old honda luckily my accords was part of a recall so it was free, start there all of my cars with the problem did exactly the same thing
Old Jan 21, 2012 | 09:26 PM
89CRXSi_24's Avatar
Default Re: HELP!
so what do i do to it? test it and if it is bad then what?
Old Jan 21, 2012 | 10:03 PM
dylaxiin's Avatar
Default Re: HELP!
replace it mark.. haha
runitup
21
Dec 26, 2020 05:17 PM
EF_LSVtec
10
Jan 27, 2017 04:36 PM
itslogz
Apr 4, 2010 08:21 PM
allsho
Feb 10, 2007 05:05 PM
NXAccordTO4B
Sep 10, 2002 05:34 PM
