Turbo J32A2 S2000 Build Thread
Well I guess its time to start a build thread since its finally starting to look like something. I purchased my 2002 S2000 in October 2009 and bought the J32a2 two weeks later. Both the car and motor were bought just for this swap. My main thought behind the idea was to have a s2000 with some much needed torque. FYI, the idea was before the HFP j37 Blue CR(the released pic anyway)! I will try to keep the updates not too far apart, but I only work on the car about once a month.
Construction of mounts
Motor and tranny together with temp. wooden adapter plate
with mounts tack together and ready to install in mock-up car
Manifold construction
Rev4 template of adapter with starter location
Cutting a knock out in the oil pan for the starter and checking fitment
Material for the final adapter plate
Adapter Plate, spacer, and flywheel
Starter shim and modded pan
Stepped dowel pins (thanks to turtle @ EVO IND) are an adapter plate's best friend
...going back in to continue the fab stuff
Meanwhile, the reason my S2000 was so cheap was it was wrecked at one time. Most of the damage was cosmetic, but needed to be fixed.
Back to project. Just a few pics of fit and clearance
Very nice reid.
I'm curious is this an all out drag car or something more of a street strip project?. Did you consider going with a twin turbo setup something like twin garrett gt3071r's?.
This is not reid. My name is Andy. The car will just be a sunny day driver. I doubt it will ever see the track. Twin turbos would be too tight, more money, and not as clean. The sigle turbo with a air/water intercooler keeps it simple.
As i was looking at the header fab, i was thinking to myself...why are they facing the front....and then BAM turbo in the face! Very nice cant wait to see finished product.
My bad andy. I love the fab work. I look forward to the progress of this build.
