Oil cooler on LS block?
Old Jan 15, 2012 | 05:12 PM
diablo2184's Avatar
Default Oil cooler on LS block?
Does the LS block have the port for an ITR oil cooler? I know you can use the cooler on a GSR block, but I dont want to purchase one and it not work on my LS.
And is so, what other parts do i need to get it compatible with my motor?
thanks.
Old Jan 15, 2012 | 09:12 PM
mouab18c1's Avatar
Default Re: Oil cooler on LS block?
You don't even need it. I think it's a waste of money.
Old Jan 16, 2012 | 03:43 AM
mike703's Avatar
i disagree. for a street car yes youre correct theyre a waste of time and money...now on an auto-x car thats an entirely different story when an engine spends minutes upon minutes at or near redline keeping the engine cool is priority 1.
Old Jan 16, 2012 | 05:41 AM
kyden's Avatar
ls motors do not have the port for the oil cooler. you can drill and tap the hole if you want. i wouldn't do it myself but that is an option. i would probably just go for an aftermarket setup.
Old Jan 16, 2012 | 10:10 AM
1998GsRIntegra's Avatar
The oem oil coolers are a joke for anything outside of street driving. If you want an oil cooler, which isn't really necessary for a street car, you will have to get a cooler, sandwich plate, lines and fittings. I just put one on a road course only crx with a semi-built b20vtec because the oil temps were pegging on a 260 degree gauge. I opted for -10an lines and fittings. The cooler I went with was this one: http://www.ebay.com/itm/Fluidyne-The...item51930329d2 but I got it with -10 fittings as opposed to the -12 fittings it comes with.
sh!ft
Dec 10, 2010 04:32 PM
riceball777
Jan 21, 2004 06:19 PM
cock head
Oct 21, 2002 12:18 PM
boosted3g
Jan 25, 2002 03:52 PM
