P28 solid CEL but runs perfect?
Old Jan 15, 2012 | 01:41 PM
RiipTiide67's Avatar
Default P28 solid CEL but runs perfect?
I've had a chipped ecu running perfectly for several weeks, chipped it myself and ran with no check engine lights. The other day I got a solid check engine light (code 0) and I don't know why. I didn't change anything, didn't install anything, didn't tweak anything.
The solid CEL only appears when running off a chip. running it from stock gives me no check engine lights. I've check all of my connections visually and with a multimeter. They all check out fine. what would cause this check engine light to come up so suddenly while the car still runs PERFECTLY fine, no hiccups what so ever?
Old Jan 15, 2012 | 04:03 PM
HRTuning's Avatar
Default Re: P28 solid CEL but runs perfect?
If you don't have a rev limit at 3500 it's not in limp mode as a solid cel would suggest.
Old Jan 15, 2012 | 05:15 PM
GhostAccord's Avatar
What code(s) are being stored on the ECU, a solid CEL does not always mean a code 0. If you have the SCS connector jumpered/shorted with a wire/paperclip and the CEL is solid that means that there are no codes. A solid CEL while your driving just means that there is a stored diagnostic trouble code(s) on the ECU. Retrieve the code(s) and see what it says.
My guess would be that maybe the check sum has not been removed or it is an issue with the circuits that have been modified on the ECU. aka the chipped part.
Old Jan 15, 2012 | 11:09 PM
It revs fine and everything... no limp mode. With the key in the on position i jumped the connector on the passenger side under the glove box area and the check engine light just stays solid. I guess it could be the chipped part, but i think it's weird that it would just come on out of no where after reading the chip perfectly fine for quite some time, and still continue to read the chip fine even after it throws the code
Old Jan 15, 2012 | 11:14 PM
mouab18c1's Avatar
Reburn the map to see just to see if the file is corrupted. Or go through all your soldering again.
Old Jan 16, 2012 | 06:57 AM
HRTuning's Avatar
Ok, so jumping it has a solid cel... is there a cel when it's not jumped? If not then whatever code came up that lead you to check in the first place has been erased and there's no codes currently. If so maybe you have an improperly setup CEL shift light feature.
shermanyang
Jun 16, 2014 08:22 AM
project91crxsi
Feb 20, 2012 07:24 AM
EnzoSpeed
Oct 18, 2005 11:21 PM
MeanGreenEG9
Dec 4, 2002 07:58 AM
