omni map change engine dies after start
Old Jan 15, 2012 | 12:21 PM
cleanls's Avatar
Default omni map change engine dies after start
Just configured lc1 and ostrich and uploaded base to ostrich after selecting xenocron 4bar and won't run. Stock sensor works fine with the chip / street tune that was in before. Come free is what I am using and it shows 4 bar at bottom of screen so it is selected? Anyone have problem like this before with any map sensor?help?
Old Jan 15, 2012 | 05:06 PM
grumblemarc's Avatar
The Grumpiest
Default Re: omni map change engine dies after start
So why are we trying to run a 4 bar now?
Old Jan 16, 2012 | 04:49 AM
cleanls's Avatar
Stock only allows 10 lbs. I want to retune on 18 lbs maybe more in future depending on size trim maybe never higher than that . I am tuned at 10 now but any spike at all map kicks me out so no wot possible without random nosedive
Old Jan 16, 2012 | 06:08 AM
The Grumpiest
So it is not needed at this time since this isn't the future. Put the stock one back on.
Old Jan 16, 2012 | 01:23 PM
cleanls's Avatar
I am trying to retune with more boost so other than stock is required.Future in now all hooked up and ready to go other than the not running part. I know I can put the old one and chip back in to get it to run its not my dailey driver so its not like I have to drive it asap just want to retune with more boost.
Old Jan 16, 2012 | 01:42 PM
The Grumpiest
I know stock is about 10-11. You stated you were upping the boost IN THE FUTURE. That meant that RIGHT NOW it was not needed so obviously I misunderstood you. Good luck to you sir. I'd rather not risk misunderstanding you again. Sounds like your basemap needs more work.
Old Jan 16, 2012 | 02:31 PM
cleanls's Avatar
I was not trying to be a smart *** sorry if it sounded that way,anyhow I put stock map back on and left emulator with my created basemap and started with no hesitation and ran fine? Good to see run and now think sensor must be bad and will be exchanged with no hassle(cool),how and why did it run? basemap had 4 bar hondata/omni/xenocron selected not stock . Those 3 are supposedly same values. Last I checked when changing map it needs to be changed in engine management otherwise it wont run with different on selected in program>
Old Jan 16, 2012 | 08:04 PM
cleanls's Avatar
map sensor good .Omni support is awsome ! My problem was crome fuel multiplier and me thinking program from stock 240 to current 450. No crome wanted me to stay stock on injectors to run. Way too rich but it ran and I tuned it down at idle. Point being fuel multiplier does not work if you dont start from crome program then change to different crome.
Old Jan 17, 2012 | 04:37 AM
The Grumpiest
keving85
Engine Management and Tuning
Sep 25, 2009 08:10 AM
Honda4life777
Jul 6, 2009 09:00 PM
projectjazzmine
Jun 10, 2008 09:38 AM
MooreBoost
Aug 30, 2005 06:08 AM
paulzy
Dec 5, 2001 10:04 AM
