quick question, can i use this hose end on my -3 AN feed line?
I stripped the threads on my turbo feed line and would like to replace the hose end rather than the entire line.
I am looking at this hose end:
http://www.summitracing.com/parts/SUM-220140/
Can anyone tell me if this is the type of AN hose end that you "push on" (does not require a crimping tool). Also, I believe the threads on the male fitting on my turbo are 3/16". This 3 AN hose end should be compatible, correct?
It's not a socketless "push on" type hose end, but you also don't need a crimping tool for that fitting. Socketless hose ends don't work with braided hose. This link should help with your other question:
http://www.brennaninc.com/documents/...hreadChart.pdf
Dunc
Jun 18, 2006 09:30 PM
