P28 ECU not looking for o2?????
Old Jan 14, 2012 | 10:10 PM
ef yu's Avatar
Default P28 ECU not looking for o2?????
I have a crx but engine obd1 so i thought maybe this section would provide better information than the ef.
Car description.
89 crx si
Original 89 SI harness
obd0-obd1 conversion (home-made)
94 B16A
Got it running with a OBD1 P28 ecu. bought it chipped and it ran great. The problem is that my CEL doesnt come on for an oxygen sensor, i dont have one hooked. I have the 4-wire sensor but didnt have a chance to put it in. I noticed it never came on. never. drove a month and still nothing. My CEL works fine. other codes throws if i unplug the vtec solenoid. My service check switch works as well when its grounded.
My question is could my ECU be bad? i have yet to try another ecu. i dont know anyone with a OBD1 ecu. frankly its because everyone got out of the scene. For sure wiring is NOT hooked up because i made the harness myself.
I have tried different chips. even bought a couple and made sure it was not eliminated. still no-go.
Old Jan 14, 2012 | 10:11 PM
Dc4LsTeG's Avatar
EK9
Default Re: P28 ECU not looking for o2?????
It's cuz your ecu is chipped
Old Jan 14, 2012 | 10:13 PM
ef yu's Avatar
so when an ecu is chipped, the ecu stops looking for the oxygen sensor?
i mean i seen programs that are able to turn off o2, vtec speed check, knock etc....
I've bought chips that i HAD made sure the chipper enabled the o2.
Old Jan 15, 2012 | 04:59 AM
grumblemarc's Avatar
The Grumpiest
Depends on how it was mapped? Normally when you get an ECU chipped you specify the parameters of the MAP. Such as disabling O2 sensors. Did you specify this in your MAP?
If you're not getting any ill effects then leave it alone.
Old Jan 15, 2012 | 09:51 AM
ef yu's Avatar
When i ordered the chip, i ordered for an STOCK base map from a P30 ecu. The only thing that was disabled was the Knock sensor.
The car runs fine. Gets about 27-30mpg street/hwy combine. But I live in California where I'm trying to pass the silly smog.
Old Jan 15, 2012 | 09:56 AM
Dc4LsTeG's Avatar
EK9
Well it won't pass with a chipped ecu anyway..try a stock ecu and see what happens
Old Jan 15, 2012 | 10:05 AM
ef yu's Avatar
why wouldnt it pass? i mean for sure it wont pass a visual inspection IF the smog tech looks at it but its running off of a Stock, not modified P30 basemap.
Also a P30 ecu is not exactly the easiest ecu to find. I am sure if im able to find one, itll run me 200+...
Old Jan 16, 2012 | 08:53 AM
turtleef's Avatar
949-633-3981 this man here named chris (sells the p30-a00 for 4bills a pop or he will rent one to u to pass bar smogs for 150 a pop u go throo paper work and everything but least uall be legit when u go to the ref
he lives out in Lake Elsinore
DaddyKin
14
Jul 12, 2011 01:52 PM
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
Dc4iNtEgRa
Apr 1, 2010 07:59 AM
Staypuff578
Feb 25, 2010 04:23 PM
civiclxb16a
Dec 20, 2004 08:17 AM
