anyone know how to wire a distributer plugs from obd1 to obd2
so i have a 99 b16a motor, but the wiring harness of a obd1 eg6 but the plug on the obd1 has two plug, and the other has one plug is there a way to use them or sawder the other plug from the obd2 plug the obd1 harness
Yes, you can remove the 2 plugs from the obd1 harness and use the single obd2 plug. You will need to find the harness-side plug from an obd2 harness.
Learn to search. This thread took me all of 10 seconds to find, there are plenty more like it...
https://honda-tech.com/forums/hybrid-engine-swaps-18/help-obd2-obd1-dizzy-alt-wiring-1736189/
96-98 obd2a has a 10 wire distributor plug
99-00 obd2b has a 8 wire distributor plug
you have a "99" b16? assuming you have a 8 wire diz plug?
and your obd1 engine harness has two plugs
rywire makes distributor jumpers that adapt an obd2 distributor to obd1 engine harness...
http://www.rywire.com/catalog/obd1-t...pter-p-42.html
the one shown ^ here is for 10 pin dizz but call them they will have no problem making and 8pin one for you and at 35$ you can't go wrong!
i ran into the same scenario putting my obd2b d16y8 from my 99 civic ex into my friends 95 civic vx
Other than the z6 manifold obviously, i wanted to use everything stock that was already on y8 including dizz and altenator so i used both rywire diz jumper and altenator jumper
Alex Preece
Oct 24, 2018 10:31 PM
im_poor
Apr 17, 2003 11:27 AM
