Erratic speedo under WOT
Old Jan 14, 2012 | 04:05 PM
civicjunkie17's Avatar
Default Erratic speedo under WOT
Hey guys, I have a 99 hx coupe with a obd1 b18c1 in it.
Normally my speedo will work perfectly fine until I start to give it some throttle. (80% or more) when I do the speedometer needle will start to jump around going up to 140mph back down up etc. I did a few tests on the connector itself, It read like this.
Power = battery power 12v good
Signal = 5v and would pulse when I spun a wheel by hand.
Now on the ground wire I did a continuity test in ohms it read .51 Is that my problem a bad ground?
I checked all the fuses none of them popped or anything.
Thanks in advance
Old Jan 15, 2012 | 06:19 AM
rayvo's Avatar
Default Re: Erratic speedo under WOT
sounds like a bad ground... check ground from chassis to trans?
Old Jan 15, 2012 | 12:38 PM
Yeah that ground is fine. But I was thinking the same thing... Appreciate the help man.
Old Jan 15, 2012 | 02:51 PM
Anyone?
Old Jan 15, 2012 | 06:49 PM
Please? I've searched and never found a definitive answer.
Old Jan 15, 2012 | 11:19 PM
wholesaler's Avatar
check back of cluster all the screws are tightened?
Old Jan 16, 2012 | 12:44 PM
^^Thanks for the input. I'll have to give it a shot. Not sure if it's a ground of not because I checked a few today and they were all fine. Maybe I'll have to check the one going into the vss itself. Could also be a corroded plug I'm going to stop by a junkyard tomorrow a splice into one.
Old Jan 16, 2012 | 02:54 PM
cadwiese's Avatar
i had this same issue and i took my speed censor out and cleaned it. no more problem
Old Jan 16, 2012 | 03:36 PM
What part did you clean? The plug? I've done that, it works for a few miles, which leads me to believe it's the plug...
Anyone else? I appreciate the input guys.
Old Jan 16, 2012 | 03:45 PM
H22AFerio's Avatar
It does sounds like a Ground /Ground loop problem... Have you wired up a stereo or amp lately?
Old Jan 16, 2012 | 04:24 PM
Marvin1985's Avatar
http://techauto.awardspace.com/vss.html
Old Jan 16, 2012 | 06:59 PM
Originally Posted by Marvin1985
Thanks man! I'll give this a shot and report back.
92eg6_pino
Oct 9, 2010 04:56 PM
CBEengineering
17
Feb 25, 2009 07:23 PM
cvcrcer
Jul 6, 2005 01:33 PM
jweller
Sep 29, 2002 09:45 PM
Leets
13
Mar 13, 2002 06:09 AM
