98 GSR Crank No Start
Old Jan 13, 2012 | 05:14 PM
96GeeSR's Avatar
Default 98 GSR Crank No Start
Have an issue with a 98 DC2. Car cranks but does not start. Tried replacing with a good ecu, distributor, main relay and a no go. When i put the key in the on position the fuel pump does not prime. Any ideas on diagnosing if it is indeed a faulty fuel pump?
Old Jan 13, 2012 | 05:28 PM
TheRealTegger's Avatar
Default Re: 98 GSR Crank No Start
When you first turn the key to "II", does the Check Engine light come on for two seconds then go off?
Or does the Check Engine light behave differently from the above question?
Is the fuel pump original, or aftermarket?
Please answer all the questions, not just one of them.
Old Jan 13, 2012 | 06:20 PM
96GeeSR's Avatar
Yes check engine light comes on and back off after a few seconds. I have no idea about the fuel pump I haven't opened it up or changed it as I got the car not too long ago.
Old Jan 14, 2012 | 09:35 AM
96GeeSR's Avatar
Anyone have any ideas? I'm stumped.
Old Jan 14, 2012 | 11:41 AM
Jump the fuel pump directly to the battery. If it runs, it's good. If it does not run, then it's bad.
Old Jan 14, 2012 | 11:45 AM
el crapitan's Avatar
lol. if the pump doesn't run, i'd think it would be instinctive to check it's operation before changing a bunch of other parts, no?
Old Jan 14, 2012 | 12:14 PM
96GeeSR's Avatar
How would i just the pump directly to the battery? I'm also getting no spark either. So and this happened at the same time. I didn't drive the car for 3 days then it wouldn't start. All ground wires are good, relay is good, ecu is good.
Old Jan 14, 2012 | 12:27 PM
stocker2shocker91's Avatar
I requested a short story for a title.
with that being said how sure are you that the fuel pump is not priming? the spark could be the whole issue. does it smell like gas around the engine bay fairly strong??
Old Jan 14, 2012 | 12:37 PM
96GeeSR's Avatar
No smell of gas in the engine bay, and when i put the key in the on position i dont hear it prime, when before it did.
Old Jan 14, 2012 | 12:47 PM
hmmm,, sounds like there could be wiring issue somewhere since you said u changed the ecu and main relay out, this may sound wierd but where was the car parked in the three day u didnt drive it? I have heard to many times of rodents gettin up in the engine bay and chewing on wires.
sounds crazy but maybe check it out
it should deff be throwing codes of some sort though
Old Jan 14, 2012 | 12:50 PM
fcm's Avatar
fcm
Old Fart
The first thing you need to do is check the operation of the PGM-FI Main Relay.
The first test is a simple feel/listen test, [easiest to do if you drop the relay] hold the relay in your hand and turn on the ign. switch to run, [not all the way to start] you should feel/hear two (2) "clicks", it may feel/sound like one click as they are very close together, after a few sec. [or less] there will be a third click.
The first click is the injector relay turning on, the second click is the fuel pump turning on, the third click is the fuel pump relay turning off, [after priming]
If you are not feeling the clicks you will need to do some testing, unplug the relay and test for powers, there are three (3) of them...
1- Yellow/white, hot at all times, fuse 44 -15A, [engine bay fuse box].
2- Yellow/green, hot in run and start, fuse 13 - 7.5A, [under dash fuse box].
3- Blue/white, hot when cranking to start only, fuse 31 - 7.5A, [under dash fuse box].
If all the fuses are good, [you have all three powers at the relay plug] test the ground, [black] , if good, use a jumper to connect the yellow/white and the yellow/green, [there are two (2) yellow/greens, one is the fuel pump power lead and the other is the fuel injector power lead, one of them should turn on the fuel pump, if it does... http://www.tegger.com/hondafaq/mainrelay.html
If all the above is good, test for power at IPG1 and IPG2 at the ECU/ECM, [both must have power] they are the only two yellow/black leads at the ECU/ECM.
Old Jan 14, 2012 | 01:06 PM
96GeeSR's Avatar
I feel the 3 clicks, the first 2 do feel as one but it's a quick double click. How would I check the black groud you mentioned? And for the jumper test this is done at the connector that plugs into the main relay correct?
Old Jan 14, 2012 | 01:39 PM
96GeeSR's Avatar
The car was parked in my driveway, and no it's isnt throwing any codes. Could it be the crank sensor?
Old Jan 16, 2012 | 03:49 PM
fcm's Avatar
fcm
Old Fart
That is correct, jump from the yellow/white to the yellow/green, one of the yellow/greens is the output from the fuel injector relay, the other yellow/green is the output from the fuel pump relay, jumping to the yellow/green injector relay output would get you power to the injectors, when you jump to the fuel pump relays output the fuel pump will, [should] turn on.
The ground for the PGM-FI Main Relay must be good or there would be no clicks.94
tonyj
Oct 31, 2024 02:26 PM
Djfox
Apr 20, 2018 11:13 AM
GsrTeg95
Apr 9, 2011 01:40 PM
abadkevin
May 14, 2009 09:19 AM
redcivicgsr
Jan 13, 2004 07:06 AM
