AEM EMS Series 2
Old Jan 12, 2012 | 03:29 PM
Kane666's Avatar
Default AEM EMS Series 2
I currently have these mods
AEM V2 w/ AEM Dryflow Filter
Professional Products 68mm Polished TB
Rosko ported & modded 68mm Euro R Intake Manifold
NGK 7mm Spark Plug Wires
Hytech Replica Header 2.5"
Magnaflow Metallic High Flow Cat I/O 2.5"
2.5" Resonator
Kteller 2.5" T304 Piping
Vibrant Muffler 2.5"
AEM Pulleys
aem ems series 2
tuning done to produce 170whp and 129.06trq
AEM wideband
stock injectors
walboro 255lph pump
May or may not help:
CC Delete (Intake air isn't going that way)
Deleted EGR (IDK if it hurts)
M2Y4 Tranny (bwah)
Mishimoto Radiator
Mishimoto Fans
B&M Tranny Cooler
I had complained about shitty ~21mpg with a stock ecu and now after all this have a whopping 17mpg after power and "fuel tuning" What the hell is going on that my mpg dropped? When I went there I was told I would get more power and better mpg and even went back for the fuel tune after the initial tune on the dynojet. He's saying if I went at a constant 60mph with barely touching the gas I'd get 35mpg. Now of course that will never happen but I'm leaned out a lot and barely ever hit VTEC. He says it'll go up in summer and doesn't want to lean it anymore drastically. I know I have an auto but this is ****ing silly. His wife's tuned 5peed gets 29mpg combined. Why is mine so difficult?
Old Jan 14, 2012 | 12:07 PM
gstrudler's Avatar
Default Re: AEM EMS Series 2
Need an AFR graph to know what is going on.
Old Jan 14, 2012 | 01:29 PM
Hawkze_2.3's Avatar
Yep...the dyno numbers don't help with MPG questions.
Maybe your tuner isn't very good at tuning for MPG on the aftermarket ECU?
Old Jan 14, 2012 | 08:04 PM
Kane666's Avatar
AFRs are 12.7-12.9:1 under wide open throttle conditions.
Old Jan 15, 2012 | 12:08 AM
AznBlueBoy's Avatar
And again. This has next to nothing to do with your mpg.
It could be a bad tuner though or maybe you have other issues. Power seems low too.
Old Jan 15, 2012 | 02:42 PM
Kane666's Avatar
its an automatic.
Old Jan 15, 2012 | 03:03 PM
AznBlueBoy's Avatar
its an automatic.
5spd will give you more power and better mpg.
Old Jan 15, 2012 | 08:21 PM
gstrudler's Avatar
Was this only dyno tuned at WOT? If this was never street tuned and/or part-throttle tuned, it's not all that surprising you're getting the results you are.
Old Jan 16, 2012 | 08:27 AM
Kane666's Avatar
dyno tuned for the power, driven around for a week and tweaked for the gas. i know 5spd will give me better everything, isnt an option right now.
Old Jan 16, 2012 | 08:00 PM
AznBlueBoy's Avatar
street tuning for a week?
Who did this?
Was a wideband used?
You can tune partial throttle on the dyno as well.
Street tuning is not the best IMO unless you're making final adjustments at the track after a proper dyno tune.
Old Jan 17, 2012 | 12:01 PM
Kane666's Avatar
on and off for a week
dms performance in dillsburg,pa. hes been tuning since late 90's
yes
proper power dyno tune was done on a dynojet. gas tune done under normal driving conditions.
Old Jan 18, 2012 | 03:46 PM
AznBlueBoy's Avatar
yes
I had my WOT and partial throttle tuned on the dyno.
Dynojet and dynapack.
Doesn't matter how long hes been tuning. The local tuner here tuned my motor at first and I went to someone good and it ended up making more power and ran way better.
Old Jan 18, 2012 | 04:30 PM
q16racer's Avatar
are you still running the TCU?
daigo
Engine Management and Tuning
Apr 26, 2015 09:11 PM
blk007
May 13, 2007 08:31 PM
slimcivic95
Jan 26, 2005 09:31 AM
blacklabelboarder
Mar 24, 2004 11:47 AM
