i have 2 cel codes... how to fix??
If it's not a VTEC, which you really need to verify, then your ECU is looking for VTEC components it doesn't have. As long as it doesn't find them you will have codes thrown. My guess is that if the engine is not VTEC you have the wrong ECU installed.
For clarity, it's on the left of the block, just below the head. You may have to clean it with some purple power or other grease cutter - if you've never seen it before, they can get coated in grease and road grime.
Gah, beat me to it. Wrong ECU for the motor. The correct ECU is a P06. You can either swap on a vtec head, swap to the correct ECU, or get the ECU chipped and tuned to delete vtec.
= Frequently asked question.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
lamafia781
Jan 20, 2011 12:15 PM
