D16z6 weird noise on start up(video)
I got a eg coupe
D16z6 vtec running on p28
Never had problems with it
Besides squeaky alternator belt
Which you'll hear in video
But today out of nowhere
When I started my car
It made a loud nasty
Noise then started and ran good
I turned it off then on
And again on startup sounds bad
But still turns on and runs good
Any help is appreciated
Will post better vid in morning
If necessary
Not sure if u can hear it that well
In the video
http://i1214.photobucket.com/albums/...z/fc36647e.mp4
If necessary
In the video
Well first, get that belt changed. And as for the sound, it sounds like a normal D16Z6 to me tho..Maybe take a video while driving, maybe it`s louder than?
http://i1214.photobucket.com/albums/...z/b48ed6f2.mp4
Alright here's a better video
You can hear how bad it sounds
Had some guy Check it out at work
He said something about sounds like
Starter messin with the clutch
Something like that
Anybody know anything like that?
Something like that
yea that sound is not good
and why dont u just fix the belt
all you gotta do is loosen the alternator two nuts and make the belt tight and bolt it back up
if you think its the starter just take it out and get it to kragen or autozone for a free check to see if its working
theres two 14mm bolt one on top and one on bottom you will need a longer attachment for the bottom one
good luck
good luck
What your guy at work was referring to is the starter wheel sticking and the flywheel spinning the starter. When you try to start the car does it crank over still? May want to take the starter off, check the teeth on the starter wheel and flywheel. Good luck
Yeah yesterday it made that noise
But still turned on and ran good
I push started it at night when I got
Out of work and it started right up with no
Noise
Today in the morning
It doesn't even turn over
Just makes this loud ugly noise
Kinda like if u grind a gear bad
And it don't start
Hopefully it's the starter
Will post pics and vids In morning
To see if I can get some help
Thanks
Noise
And it don't start
Thanks
Yeah id say def check the starter... It sounds like when your cars started and you try turning the key again... check all the teeth on the flywheel
Problem solved
Replaced starter and starts right up
Also tightened alternator belt
So no noise
Thanks for help
http://i1214.photobucket.com/albums/...z/d3fe63b4.jpg
So no noise
Thanks for help
Evolutionjuan
Aug 18, 2013 10:21 PM
cr2250
Dec 21, 2010 05:00 AM
