Cruise control wiring
Old Jan 11, 2012 | 02:13 PM
riceburner94si's Avatar
Default Cruise control wiring
I have five wires at the steering. They are labeled 22, 23, 24, 01, and 02. 22 is the horn. Does anybody know what two wires control the cruise. The link I found uses the wires at the fuse panel and I would like to keep as much in place to put back to stock if need be. This is in a 94 SI.
Old Jan 11, 2012 | 04:44 PM
Default Re: Cruise control wiring
23 is set and 24 is reset. If you use the stock switch there is a single pin and a space then three more pins. Leave the first alone. Next one over is power in. next one over is reset whick you would connect to the wire marked 24. Last one is set which you connect to the wire marked 23.
DC4_Dad
Dec 13, 2018 04:13 AM
JMF7054
Feb 19, 2007 09:09 AM
TurboTeG4
Audio / Security / Video
Oct 3, 2005 05:53 PM
B18EG6
Jun 26, 2003 08:37 AM
