I need help
Old Jan 11, 2012 | 06:06 AM
Crex167's Avatar
Icon3 I need help
i recently bought a crx, the car was sold to me with the timing advanced back firing and sputtering. the car idled at 2000 rpms, it drove perfectly, a little low on the mpg and the car doesnt do well when the tank is pretty low... i retarded the timing back to stock and she idles low but she isnt strong.. once i give it gas or its been on for a little the cars check engine light will come on and the rpms will go up then go right back down... im thinking fuel pump i just need more opinions before i take any action and need recommendations on whether i should just buy an autozone fuel pump....
in the video i turn the car on and let it idle... i give it gas and then the check engine comes on.. then when i finish giving it gas it dies out... then i turn it back on to give it gas and have it die out again.. someone please help your suggestions and input will greatly be appreciated
http://static.photobucket.com/player...108_161411.mp4
Old Jan 11, 2012 | 06:20 AM
91 EF DX's Avatar
Default Re: I need help
Check the timing marks on it and make sure it hasn't jumped
Old Jan 11, 2012 | 06:31 AM
Crex167's Avatar
for the timing belt? and im sorrry i didnt mention that i drove the car 2 hours already but when the timing was advanced
Old Jan 11, 2012 | 07:36 AM
91 EF DX's Avatar
Yeah. Check the mark on the cam sprocket and the timing marks on the crankshaft pulley and make sure it is in time.
Old Jan 11, 2012 | 07:47 AM
Crex167's Avatar
ok i will... thanks... are there any other possibilities and suggestions? i was pretty sure it had something to do with fuel, because the car doesnt do well at all with low gas and does fine when i open the throttle a bit
Old Jan 11, 2012 | 07:55 AM
axis11's Avatar
Could be a combination of problems. Get rid of the CEL first. Idle is low,lots of possible causes. Start with timing.
Old Jan 11, 2012 | 08:10 AM
Crex167's Avatar
k thanks... and isnt it suppose to idle low? i always thought it was suppose to idle between 0 and the first bar on the tach
Old Jan 11, 2012 | 08:29 AM
KINGVEM^^ED6's Avatar
No idle should be right around 1000 iirc
Old Jan 11, 2012 | 08:57 AM
Crex167's Avatar
ok thanx... if anyone else has any other input it is most definitely welcomed
domrw
Honda Civic (2001 - 2005)
10
Mar 2, 2017 06:40 AM
dizzyroc88
25
Dec 2, 2006 05:13 AM
99delsol
Nov 28, 2006 08:09 PM
eg6turb0
12
Jan 15, 2005 08:02 PM
eg6turb0
Jan 10, 2005 11:44 AM
