B18cR differences from B18c
Old Jan 10, 2012 | 09:57 PM
Edwin909's Avatar
Default B18cR differences from B18c
Looking to pick up a supposedly b18cR block but what physical diffreneces can i look for to distinquish the difference between the two?.... example pistonds, crank, girdle anything to help me not get ripped off.
Old Jan 10, 2012 | 10:02 PM
.Manny.'s Avatar
Touching My Member
Default Re: B18cR differences from B18c
Do a search for all the details.
The ITR crank has an "R" cast onto one of the counterweights. I do believe the rods have P73 cast on there as well
Old Jan 10, 2012 | 10:49 PM
whited's Avatar
CRX God
Look at my thread from my signature I have pictures of my type R engine.
You should have a 4 to one header. The head should have the year in one of the circles. And the transmission should be stamped LSD N3E, but the stamp wears off since it is ink.
Inside the CAM looks different, the crank is thicker with the R on it, and the final gear to the transmission is different.
Oh and everything is marked P72 or P73.
Old Jan 11, 2012 | 01:24 AM
TeamRedline89Hatch's Avatar
Oh and everything is marked P73.
My friends 96 type r is stamped j4d lsd and had a 4-2-1 cast manifold.
Old Jan 11, 2012 | 01:58 AM
Edwin909's Avatar
Remember guys im only looking for detials on the block, the R mark helps a lot but ive also heard of Gsr engines having p73 stamped on the rods, is there any diffrences between the girdles and i aldo heard that the b18cr has a small oil cooler between the oil filter but then i heard that all b18 vtecs have it also just need some confirmation.
Old Jan 11, 2012 | 03:33 AM
If a gsr block has p73 rods or pistons they have been swapped with itrs. If it comes with a flywheel the itr weighs about 5 lbs less. My gsr weighed 19.4 lbs and my type r weighs 14.9 both factory and resurfaced.
Old Jan 11, 2012 | 06:11 AM
whited's Avatar
CRX God
Oh I was assuming he was talking about a 98 Type R.
Old Jan 11, 2012 | 02:06 PM
Edwin909's Avatar
whats the stamp on the pistons?...
Old Jan 11, 2012 | 02:50 PM
88LsRex's Avatar
b18c = P72
b18cR=p73
The block will be stamped P72 on the back, The crank should be stamped P73 and the pistons should also be stamed P73, the head should be stamped PR-3.
Old Jan 11, 2012 | 03:21 PM
Edwin909's Avatar
does the p73 stamp on the pistons apply also on the usdm type r
Old Jan 11, 2012 | 03:37 PM
88LsRex's Avatar
Yes.
Old Jan 11, 2012 | 03:48 PM
Edwin909's Avatar
ok thank you guys for the help its gladly appreciated.
Old Jan 11, 2012 | 03:50 PM
88LsRex's Avatar
no problem.
Old Jan 11, 2012 | 05:50 PM
jdmboyef9's Avatar
Block wise they are the same. By looking at it the only give a way is the pistons should say P73 on the tops. The crank and rods are different as stated above, however if you drop the oil pan both gsr and type r say p72 on the bottom rod caps. The rods have an R on the side and the crank has an R only visible from one side. Most cases the pistons are your best id but clearly not %100
Old Jan 11, 2012 | 06:00 PM
whited's Avatar
CRX God
I do believe the the block does have a p72 stamped on it on the back by the transmission.
Here are pictures of my 98 spec JDM. (Hopefully they are all right)
Old Jan 11, 2012 | 06:13 PM
88LsRex's Avatar
Old Jan 12, 2012 | 06:17 AM
Deetz's Avatar
Crazy Honda Guy
The P72 engine block was used on all GSR, ITR and CTR engines
As pictured above, the easiest way to identify a true ITR engine is pop off the oil pan and look and the crank and rods. Also, the head should be a pr3 with P73 intake manifold. The The bracket where the optional a/c is stamped P73, and all itr has the aluminum engine brace on them that connects the engine to the tranny
Old Jan 12, 2012 | 07:24 PM
jdmboyef9's Avatar
What Deetz said
Old Jan 21, 2012 | 10:49 AM
whited's Avatar
CRX God
Here is the picture of the AC bracket, and the upper power steering bracket.
Old Jan 21, 2012 | 07:59 PM
Edwin909's Avatar
You guys are beyond awesome this really does help a ton and i know the head is suppose to be stamped pr3 but this engine im trying to pick up has a gsr head, the seller said he like the smaller combustion chambers but he has the head buyilt to type r spec
i just wanted to know for sure the block was a type r and not a jdm gsr and you guys rocked it:D
anyways i have a few questions first whats this aluminum engine brace and will that affect my transmission options
secondly whats that gasket whited posted up of?.....
Old Jan 21, 2012 | 08:47 PM
whited's Avatar
CRX God
Throttle body gasket, the label actually says it in the picture. The left is a gsr, the right is either a usdm or jdm type R. The intakes for the type Rs are larger.
Old Jan 21, 2012 | 10:19 PM
Edwin909's Avatar
Oh wow your right i feel dumb, well im not to wooried for the throotle body gasket the engine is fully rebuilt with zero miles and has a skunk2 intake mani so im sure he took the extra steps to get anew gasket for the TB anyways whats this aluminum engine brace, i just want to know if itll affect me trying to put my A1 transmission on there
Old Jan 22, 2012 | 06:30 AM
whited's Avatar
CRX God
The AL stiffener is in the picture with the oil pan. It wraps around the oil pan, bolts into the engine and transmission. I don't know if it is causes a different bolt pattern, I think the AL uses the same pattern. The AL is just larger and stronger.
Here are pictures of what others have. It is a clutch dust shield and a none wrapping arm.
Also a picture of just the stiffener.
Old Dec 29, 2013 | 09:23 AM
L.D. built's Avatar
Yup don't forget that brace between the engine and transmission, it reduces flex under sum serious power loads.
Old Dec 30, 2013 | 06:58 AM
Deetz's Avatar
Crazy Honda Guy
all itr have the aluminum engine brace on them that connects the engine to the tranny
it has been mentioned
Moonraker09
Transmission & Drivetrain
Dec 19, 2017 12:02 AM
aznej2
Oct 22, 2005 05:09 AM
lysergican
Sep 5, 2003 11:56 AM
ITR21
Sep 14, 2002 12:20 AM
posixhacker
Jul 21, 2001 02:43 AM
