Installed header now Tach, signals and hazards blow
Hey guys, I wanted to mention NEVER buy a header from Ebay, I just got it installed and It heated up hella fast and was spittin oil out of the exaust. So I installed my OEM manifold, now I'm losing compression and with my car started every time with the headlights on (or off in that matter, maybe just because the car is running,) I turn on my Turn signal/hazards, and the fuse blows. Also my dash gauges stop working (same fuse as tail lights.) I am planning on doing a Z6 head swap/OBD0-OBD1 because I'm done with the 88-91 heads, the dam ezaust manifold studs are strippin out, I have bolts in 4 out of 8, So I know for a fact thats not where I'm losing compression. Any insight on this information would be Greatly Appreciated.. Thanks again Honda-Tech
You need to figure out what you messed up when installing the header, as the header itself would not cause anything you describe.
Check everything you touched when you put it in.
Look, installing a "header" won't cause a single (not even remotely) one of your described problems. Clearly you don't understand how an engine works, because compression stays inside the cylinder. This is where the "bang" is made... The only thing electrical on your exhaust is an O2 sensor - which has absolutley NOTHING to do with the head lights. If you can't even install a "header" properly, what makes you think you can do an OBD conversion AND swap a cylinder head?
Just take it to a mechanic or sell it, that is my "insight".
PS - You made me laugh so much and so hard my sides hurt.
This is a simple fix, the ebay header is grounding out (metal to metal) which is why the fuses keep blowing. It is also likely too big of piping which is why you are lossing oil and compression (syphon effect).
You can fix everything by using a rubber or paper gasket.
And yeah make sure you get the high temp rubber or paper gasket for your exhaust manifold!
HA HA
work slow when you work on your car and make mental note of everything you touch and think of the effects it can have
I'm thinking you shorted a wire somewhere
Ok guys settle down lol, It's just a coinsidense that all this **** happened. As far as the fuses, I had a crack in my driver turn signal housing and it was shorting out because of the condensation inside. And as far as the exaust problem, I just reset my ECU and cleaned the O2 sensor now i'm good to go. Thanks for all the derogatory statements guys
You guys crack me up
I opened up thread and was reading.
So I was like,
but then...
...I was like
Hey guys, I wanted to mention NEVER buy a header from Ebay, I just got it installed and It heated up hella fast...
but then...
...and was spittin oil out of the exaust. So I installed my OEM manifold, now I'm losing compression and with my car started every time with the headlights on (or off in that matter, maybe just because the car is running,) I turn on my Turn signal/hazards, and the fuse blows. Also my dash gauges stop working (same fuse as tail lights.)
dfoxengr
27
Mar 2, 2009 08:27 AM
crazypot4200
Feb 12, 2008 10:12 AM
sleeepy
Apr 3, 2003 01:42 PM
Honda318dx
Feb 26, 2002 07:43 PM
