B18A1 NA Build
Old Jan 10, 2012 | 06:43 AM
Slinky85's Avatar
Default B18A1 NA Build
What's goin on people? I have my first Integra, had a few hondas in the past mainly accords and built those pretty well. The B18 seems similar but new to me. I already swapped in a new head because I had a blown valve, clearly the previous owner ran Nitrous. The piston rings are getting a lot of blow-by and I'm burning more oil than I should so I have a head and currently looking for a block. I'd like to build it from the bottom up, but I'm not looking to boost it as it is my daily driver. Any good ideas for good parts thing that match and don't, on a budget. I don't have 10k to drop into it. Thanks.
Old Jan 10, 2012 | 09:27 AM
Gsrsi's Avatar
Default Re: B18A1 NA Build
Well if your basically engineless then you should look into just buying a b18c1(gsr engine). There from 800-1500 depending on area mileage and if it comes with a tranny. If not you look on Craigslist for a new b18a1. I don't know how much these go for because there a little harder to come across. But if none of this is appealing to you and you want to just build the motor you have, then look into high compression pistons. Generally n/a builds are high and fi builds are low (compression). Maybe get your block bored and some cams that won't over cam the pistons you have. Also get new springs retainers and valves when you upgrade your cams.
Old Jan 10, 2012 | 09:31 AM
bryan24207's Avatar
where can i find a b18c so cheap?? ive never seen them under 2500
Old Jan 10, 2012 | 09:32 AM
Gsrsi's Avatar
Bro a b18c is a Jdm itr engine
B18c1-usdm gsr
B18c5-usdm itr
B18c-Jdm itr
Old Jan 10, 2012 | 09:35 AM
bryan24207's Avatar
whoops my bad, i didnt see you said b1bc1..i still cant find them that cheap atleast not in my area
Old Jan 10, 2012 | 09:36 AM
Gsrsi's Avatar
Parts come cheaper when you live close to a big city.
Old Jan 10, 2012 | 09:40 AM
bryan24207's Avatar
i live in a huge city with a honda scene being the biggest thing here..we had an over 300 car honda cruise recently..people just over price all the **** here bc its in such demand
Old Jan 14, 2012 | 11:11 AM
Slinky85's Avatar
I was thinking about it, looked over for pistons and new connecting rods, SRP with Eagle, plus rod bearings, cams, cam gears, valves, springs, intake manifold, that alone is gonna cost me about 1700. I've already ported and polished my head, that was a freebe. With no v-tech I think I would be putting down some serious power. I wouldn't come close with a GSR swap, would I? Also, if I can open up my stock intake manifold, would I still be getting the same results as the performance ones on the market?
Old Jan 14, 2012 | 11:22 AM
DirtyDA9's Avatar
You will have a little more torque than a GSR would, but even with a built LS head it will not rev as high as the GSR. And even with all that put into, you will be lucky to hit 230hp NA, so you may consider that serious power, but I vote LSVTEC or Boosted LS.
Old Jan 14, 2012 | 12:37 PM
Slinky85's Avatar
I see what you're saying, boosting might be a better way to go. But then I would need to get a whole buncha components to run it, turbo, turbo manifold, injectors, etc. I'm trying to keep it a daily driver with a kick to back it up with. Found a B18C1 with no trainy and 94k for 1700, doesn't seem worth it, considering I can just rebult the engine with performance parts. Or worst comes to worst just rebuilt it to stock specs and keep my bolt ons. Another thing I was wondering, I baught a high end APC front strut bar and it won't fit due to my ABS pump. Are there strut bars to fit? Or do I need to remove the pump?
Old Jan 14, 2012 | 12:39 PM
Slinky85's Avatar
Basicly my engine life is coming to an end and I want a new one for the best buck, but won't buy a junk yard motor cuz I'm planing to keep the car for some time.
Old Jan 14, 2012 | 03:33 PM
DirtyDA9's Avatar
If its a daily, I say GSR with bolt-on's. That will be more reliable than a built LS and the engine has better power potential.
Old Jan 15, 2012 | 12:22 AM
JdmTypeRdc2's Avatar
When I read the title, I immediately thought: waste of time.
The LS motor is better off left alone or boosted to make decent power. You will be lucky to see anything over 200whp NA and that's after spending gobs of money to get there.
It's not worth it. Best thing you can do is to start off with a better platform, such as a GSR or something along those lines. Depending, of course, on what your budget allows.
Old Jan 15, 2012 | 08:05 AM
Jeffaj20's Avatar
Scour craigslist, lol
Thats why my turbo project is so cheap atm lol
You can find engines online but you can get lucky on CL depending how dedicated you are
Old Jan 15, 2012 | 10:44 AM
B20ztek's Avatar
^This. if you found a GSR for 1700, I'd jump on it. You won't have to worry about building your motor, which costs alooot more than just the parts trust me and it adds up quick.
With just the gsr motor stock, it'll be pretty quick. A Big step-up from your b18a1.
Old Jan 15, 2012 | 11:38 AM
Slinky85's Avatar
Good point, but the gsr b18c motor won't work with the trainy I got, will it? I hate the way it feels like it neds a 6th gear anyway, but if I can avoid it i'd like too.
Old Jan 15, 2012 | 11:54 AM
B20ztek's Avatar
Yes it will, all B-series trannys are interchangeable.
DirtyDA9's Avatar
It will work with your tranny, they are both YS1 tranny's, they GSR just has shorter gearing. I recommend upgrading to a GSR tranny later on. You will get the most out of the VTEC motor with a VTEC trans.
Old Jan 15, 2012 | 12:19 PM
el crapitan's Avatar
for the price of that b18c1, you could get a b20z AND a decent shorter geared tranny, like a jdm y1 or something along those lines.
honestly, i had a b18c1 in one of my old da's w/ls tranny and i was not impressed whatsoever. the tranny makes all the difference.
with a b20z, you won't need to change the pcm, buy a jumper harness, or wire in vtec.
drop it in as stock and go. that right there alone is a great savings.
plus, a b20z is going to be much cheaper and this way you can throw the tranny and engine in one hit instead of one by one.
you want a little kick, best bang for your buck, there it is. simple. cheap. reliable
just make sure you get the b20z and not b20b1/4.
if you get the b20b, check that there is a knock sensor on the back of the block. this confirms that it is a high compression motor from japan, outfitted with the phk pistons.
Old Jan 15, 2012 | 12:23 PM
you want even better than that? find one outfitted with a p8r head.
you can not beat that combo for the price
enlque
Apr 8, 2014 06:34 AM
originalsin
Nov 2, 2004 08:32 PM
frenchy
Jun 2, 2004 01:10 PM
98R #448
Nov 1, 2001 08:17 AM
