Maybe Iacv, please watch video
Old Jan 9, 2012 | 06:59 PM
jaap_15's Avatar
Default Maybe Iacv, please watch video
So i recently swapped a b16 into my eg and it idles really funny, i've been searching but i still can't figure out, i already cleaned the iacv, and i will be replacing the iacv soon to see if that was the problem? and it only idles like that when its in neutral, any suggestion?
http://youtu.be/pGgnr-0JYIc
Old Jan 10, 2012 | 06:41 AM
jaap_15's Avatar
Default Re: Maybe Iacv, please watch video
bump
Old Jan 10, 2012 | 06:48 AM
StreetsideStig's Avatar
I assume you've checked for vacuum leaks?
Old Jan 10, 2012 | 07:36 AM
sde780's Avatar
Does it do that when the car is warmed up?
Check for vacuum leaks like ^he said
Old Jan 10, 2012 | 07:37 AM
Freshdot's Avatar
pull off your intake at the throttle, cover the bottom hole with your finger..if the motor shuts off its not the IACV. that looks like a faulty iacv idle though. another thing you can do is take off the iacv and wire it to a 12v source and see if the pintle is moving properly.
from my experience a vacuum leak will usually create a steady high idle or one that bounces just way slower than that.
Old Jan 10, 2012 | 09:42 AM
ReElay_'s Avatar
My idle was doin the same thing until I cleaned my iacv jus wondering wht did u use?? N if its not tht then like ^^ said probably a vac leak if its rollin
weaslehunter1
Jan 26, 2015 03:49 PM
RinzEG6
Nov 24, 2014 12:02 PM
popejooie
10
Feb 19, 2010 04:02 PM
nus_dogg
Dec 29, 2008 08:32 PM
averyvm
17
Jan 17, 2007 11:51 AM
