Wtf! need major help on this one. 2 ecu fried in two weeks...
Old Jan 9, 2012 | 03:44 PM
tvrsir's Avatar
Default Wtf! need major help on this one. 2 ecu fried in two weeks...
94 Honda civic ex. This is the second time my ecu shorted. Two different ecu. Same condition.
All this car have is an after viper alarm. Aftermarket radio and aftermarket hids.
It doesn't blow the ecu fuse it actually just blow the ecu. I'm really stumped as to why?
Any idea? Would the aftermarket alarm do this?
I would go to.work park the car for 8 hours. Come out and disarm the alarm get in. Start the car. Won't start. Check engine light stays on with no code flash when jumped. Pump won't prime and no spark.
This really sucks ecus are expensive.
Does anyone know anyone who actually repair them?
Old Jan 9, 2012 | 04:49 PM
Former User's Avatar
Default Re: Wtf! need major help on this one. 2 ecu fried in two weeks...
This usually happens when some sensor connectors are swapped. Make sure the wires in all sensor connectors match with the sensor.
Old Jan 9, 2012 | 05:25 PM
Jdubbs6101's Avatar
Deffinately sounds like you have some wires crossed get yourself a multimeter or ohmmeter and start checking wires. Also get yourself a Helms manual to check against. I would start by checking where you did the last change alarm, radio, or hids. Good luck
Old Jan 9, 2012 | 05:44 PM
94EG8's Avatar
Seagull Management
Are there burn marks on the ECU board? If so post pics and might be able to shed a little light on what's going on.
Old Jan 9, 2012 | 08:13 PM
owneyboy's Avatar
iacv/purge/iat sensors flipped or possibly tps/map? what do you mean fried post up pics
weejoeturbo
May 17, 2012 11:58 AM
Seattlepete
17
Feb 1, 2008 10:19 PM
spitfireskatr7
Aug 15, 2006 02:35 PM
gsr-2nr
Dec 29, 2003 11:25 PM
