96 Civic - passenger power window doesn't work
Old Jan 9, 2012 | 06:12 AM
Lou_EM1's Avatar
Default 96 Civic - passenger power window doesn't work
I replaced the passenger door shell recently and transferred a functional window regulator into the new door. The power mirror and lock work, but the window regular does not, it doesn't even make a sound when I press the switch. Any ideas?
Old Jan 9, 2012 | 06:36 AM
1991civiclx13's Avatar
Default Re: 96 power window
try power to the motor to see if its functional, then check relay
Old Jan 9, 2012 | 08:06 AM
Former User's Avatar
Also check for a broken wire where the wire harness passes from the cabin into the door.
Old Jan 9, 2012 | 08:50 AM
Lou_EM1's Avatar
All cabin wires to the door are in tact, unspliced, and the other power options on the door operates. The window motor should very much be functional as it was a few hours prior to the swapping of the door shell.
Where exactly is the relay located? I'm trying to follow the wires that plug into the window motor but they are very hard to see inside the door.
I also took the motor + window slider out, replugged it into the harness but it still doesn't work.
Old Jan 9, 2012 | 09:12 AM
If the driver's door power window works, then the relay is fine.
You can't always see a broken wire. You need to test the three power window wires at the passenger switch with a multimeter.
Old Jan 9, 2012 | 09:42 AM
jdmsuckah's Avatar
Check the ground
Old Jan 9, 2012 | 10:00 AM
Lou_EM1's Avatar
The relay is good then, thanks Ron. I'm willing to bet those 3 harness wires are OK too. The door seems to be very clean, nothing out of the ordinary from the looks of the wires, and def the first time stripping.
Originally Posted by jdmsuckah
Check the ground
Where? There's a ground connected to the harness, part of the 3 wires, but that runs with all the other power options which are fully operational.
Old Jan 9, 2012 | 10:03 AM
Originally Posted by Lou_EM1
I'm willing to bet those 3 harness wires are OK too. It's a clean door.
Why speculate? Test them for continuity and voltage. You'll likely be surprised by what you find.
Old Jan 9, 2012 | 10:16 AM
Lou_EM1's Avatar
Default Re: 96 Civic - passenger power window doesn't work
Correction, there are only two wires that plugs into the motor...
Swapped out the harness and now it works. Thanks all.
pdubbs
Jun 18, 2016 06:02 AM
Boss727
Mar 15, 2014 08:04 AM
alexsrx7
Aug 25, 2010 09:52 AM
Rayz_Si
Apr 21, 2008 06:17 PM
BokudenNYC
Nov 8, 2007 09:28 AM
