B16A2 Wiring harness (obd2)
I bought my civic with a B16A2 swap already done. He said it was a obd1 harness and my ignorance at the time didn't know the difference. Now that I have looked at the distributor plug wire and the injector plugs, it is clearly obd2. However, the car is running off a P2T ECU. What would be my best wiring harness to go with to allow the car to run healthy as possible?
As you may see, I am still a bit ignorant with this. I am still new to Honda's. I tend to stick with older Toyotas.
I could be completely wrong here, and if I am someone please correct me.
The P2T is OBD2, from the EM1. The B16A2 is also from the EM1, as well as a few other chassis'. Assuming I'm right, and assuming the person who did the swap used the correct OBD2 wiring harness, everything was done like it should have been, wiring-wise. Are you having any particular problems? If you aren't, I think you're good to go.
The car is running insanly rich and has some idling issues.
I'm honestly not sure, I've never been a fan of OBD2.
According to this wikipedia article, the P2T ECU is the correct match with the B16A2. The only reason I can think there would be a jumper harness is if they used an OBD1 or OBD2A harness...what the hell, that sounds like a botch job to me.
Personally, if it was bothering me, I'd pick up the wiring harness for a 99-00 Civic SI and slap it in there. Your ECU and motor match - the only mismatched part is the jumper harness.
Also, as a side-thought, take a look at the jumper harness. Is it actually changing the pinouts? Can you unplug the harness and plug the pigtails straight into the ECU without any problems? I have two jumper harnesses in my car - one for OBD2A to OBD1, and one to splice in my sensors and ****. It's possible that's why they put the not-so-jumper jumper in there.
Try removing the jumper harness and plugging the harness straight into the ECU, and see if the car starts. Worst case scenario, you get a CEL and we know there's a janky wiring job there.
Not all of the plugs will fit. A and C are the only ones that have a change of a plug. The final plug from the harness is closest to fitting the D slot since it is a smaller plug.
Yeah check your engine codes and post them. It'll be at least a glimpse into your issue. Check my sig below if you need an extension harness for your 02.
gotboosthatch
Feb 16, 2008 03:44 PM
